Old 03-27-2005, 11:29 AM
queens3358 queens3358 is offline
Just installed new sage 2.2.7. all i get is snow as a picture
Guys i need help. I just installed the new sage and all i get is snow for a picture. I have tried everything. How can i fix this. When i open win tv it works fine. I have the pvr 350 and all the updates. Sage 2.2 work fine.
Thanks.
Old 03-27-2005, 03:37 PM
buzzerbee's Avatar
buzzerbee buzzerbee is offline
Do you have the tuner set up correctly in the settings? Do you have to use ch 3/4 to access the feed?
The Antec = AMD Barton 2500+, 1 GB RAM, Epox 8rda+, WinXP Pro, PVR-250, ATI Radeon 9600XT, SageTV 2.2.8
Old 03-27-2005, 09:27 PM
i am using the same settings i use with 2.1. I also played around with other settings. I can play movies i had made with 2.1 in 2.2. But when i go to view live tv all i get is snow.
