| SageTV Customizations This forums is for discussing and sharing user-created modifications for the SageTV application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss customizations for SageTV version 6 and earlier, or for the SageTV3 UI. |
Let me see if I understand this correctly. This plugin allows Winamp to play my music files, but using the SageTV interface? So I never see Winamp? Wow, if this is how it works, I can't wait for some free time to integrate this. I've been waiting for something like this, because I'm too lazy to use Girder to do it. The best thing, is that my VFD has a plugin for displaying song information and a spectrum analyzer!!!
-Jason |
1. Default STV 2 & 3. It only happens on playlists. Would you believe that its not happening anymore. Thats not exactly the case but its not reproducable at all. Since you posted, I haven't been able to reproduce except once and I'm not sure if it was the same error. If it happens again, I'll post the DebugView log. 4. Locally 5. SageTV Should I go ahead and PM you the DebugView Log for the focus problem? I'll probablyh do it anyway, though looking it at it, it doesn't seem like it will help much. EDIT: I have been playing around wtih this more and I noticed something. When I take milkdrop off of fake full screen it starts the visualization fine and returns focus to sage, which i guess is what you want except that sage is now in front hiding the milkdrop screen. So it appears that it is returning focus to sage just fine. If i switch to fake full screen, I guess thats when its not working properly? hope that helps. Last edited by abasu2003; 12-01-2005 at 01:53 PM. |
abasu, are you using Full Screen Exclusive? I don't know how deria has implemented the visualizations, but I wonder if FSE may present problems.
To correctly support Unicode in JNI, use GetStringChars() and cast the return value to a wchar* and then use the appropriate wide character functions after that.
EDIT: I run overlay and no 3d acceleration enabled so no FSE Last edited by abasu2003; 12-01-2005 at 04:23 PM. |
I've received some feedback from Narflex @ Sage regarding the playlist not automatically moving to the next track when it should. I'll work on it more later tonight and hopefully have a fix soon.
Deria,
This is great! I just about fell off my chair when I saw the announcement over at htpcnews. I'm been waiting a long time for good visualizations (read: milkdrop) in Sage. That was one of my only remaining roadblocks from using Sage as my only front end. My only concern is how it works with FSE. Unlike what Heffe said, I absolutly need to use FSE to get stutter free HD with my 6600GT. I'm not sure how the plugin is written has anything to do with this, but I'm curious what the results are. I haven't had a chance to try it yet, and I'm not sure when I will be able to get to it. Thanks, Flips |
This looks great, but I am confused about one thing. Winamp supports tons more formats than Sage does, but does the GUI to select the music operate from the Sage database or the Winamp database? For example, Winamp has plugins that support FLAC, plus the ability read FLAC tags for metadata. Sage doesn't play FLAC or read FLAC tags into it's media database. So if I load this plugin to Sage, what happens with all the FLAC music info?
Thanks, Mike |
seeker/music_library_import_filename_extensions=.mp3,.wav,.wma
I'll add some notes to the documentation about setting that property.
Very Nice ...
Good one to add to .... Custom STV Import Modules for SageTV version 4.0 |
I have released version 1.3 of this plugin.
The changes in this version focus on eliminating the gap between tracks when playing back a playlist and avoiding early/late termination of playback for certain tracks. I've been stress testing it on my system for the last hour now and no songs are exiting early and transitioning from one track to the next in the playlist is instant. I sincerely hope that everyone else has the same experience. I also added some more diagnostic code to see if I can narrow down the problem that abasu2003 is having with the visualization returning control to Winamp instead of SageTV. NOTE: This version doesn't have unicode support. I think it may not actually be technically possible to pass a unicode string to winamp for playback. I'm investigating that. 1.3 (bug fixes) / 2-dec-2005 NOTE: The STV has not changed. To upgrade, simply unzip the new package into your SageTV installation folder (typically c:\program files\sagetv\sagetv) while Sage TV is -not- running (close it completely; do not use sleep mode). -The MediaPlayer will no longer end playback of a track in the playlist before it actually starts (or within a few seconds of starting). This issue was caused by a race condition between two threads (one thread was starting playback, and the other stopping playback because Winamp wasn't actually in its "playing" state when it was expected to be which would normally mean the end of the file had been reached). -The MediaPlayer should now move to the next track in the playlist instantly (ie: no more gaps between tracks). -The MediaPlayer will no longer attempt to seek past the end of a track. It now faithfully does bounds checking, and returns the actual new seek position to SageTV. |
#35
I am trying this out and and having some issues. SageTV and Winamp CPU usage are combines 100% so SageTV becomes unresponsive. It does seem to be working as Winamp plays the selected songs but Sage jsut basically hangs. If I stop playback SageTV CPU usage goes down and SageTV comes back.
#37
On further investigation it seems to be for my DRM'd wma's.
#38
Also, while I am integrating with with SageMC, I noticed soomething missing from your instructions.
There is a second way to get to the Visualization. The Now Playing icon can be clicked and if the current menu is the Playlist Details menu it goes to the visualization. |
#39
Was there a recording going on at the time that this happened? |
#40
| Display Modes | |
