| SageTV Customizations This forums is for discussing and sharing user-created modifications for the SageTV application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss customizations for SageTV version 6 and earlier, or for the SageTV3 UI. |
Version 1.x of the simple web radio plugin STVi provides better playback control and additional artist information.
This plugin supports the following streaming formats: - shoutcast - icecast If you want support for other stream formats like wma (including Sirius, XMRadio, LastFM), take a look at my new plugin SlimPlayer here http://forums.freytechnologies.com/f...ad.php?t=20296 You can find thousands of free streams from all around the world in genres such as music, news, comedy, etc via these links: www.shoutcast.com http://dir.xiph.org/index.php www.di.fm In general streams listed with the WinAMP logo work with this plugin. Screenshots ![]() ![]() New features v1.x
The plugin supports playback control by remote for the following commands: volume up, volume down, mute, SKIP FW#2, SKIP BCK#2, play and stop. You can have direct access to the web radio menu from your remote if you map a button to the custom2 Sage command in Detailed Setup>Commands> link Infrared/keystroke to Sage TV command. This way you don't have to turn on the tv set to start listening to the radio. From anywhere in the Sage TV menu tree, pressing the mapped button and then the play button will start playback of the the last playing station. Known Issues
Configuration You can add new stations by editing the stationlist.txt file located in the sagetv instal dir. Each line defines one station and consists of the display name of the station and the url of the shoutcast stream separated by a comma. What I normally do is go to the shoutcast website (www.shoutcast.com) choose a station from the list, right-click on the tune-in button and choose save-as to store the file locally on e.g. the desktop. Then I open up the .pls file with notepad and copy the url part from a line that reads something like: File1=http://64.236.34.97:80/stream/1006 and put this text starting from 'http:' together with the stationname in the stationlist.txt file. After reentering the Web Radio menu you should be able to select the new station and listen to it. If stream is sometimes interrupted then try increasing the buffer size by creating a webradio.properties file with following line: buffer=64000 and put this properties file in the same folder where the stationlist.txt resides. The buffer size default value (if you don't set the buffer property) is 16000. You have to restart Sage for the new setting to become effective. Installation
History v 0.1 - 06-09-2006 first version v 1.0 - 18-09-2006 new features:
new features:
v1.2 - 14-04-2007 fixed bugs:
Thanks for all your positive feedback, Enjoy!! Last edited by koelec; 04-15-2007 at 07:00 AM. Reason: new version available |
If not you may have to modify the stv file manually to create a menu item linking to the WebRadio screen.
ok ...but how i will make this?
Sage V7x: Server - Lenovo K320 with WindowsHomeServer2011, 10 Terabyte HD's on stablebit drivepool, (1 x DuoFlex CT Octopus PCIe DVB-C 4 Tuner all with LM-DVB-SmartRecorder, dbox2, run SageTV as Service, DeskNow Mail and Collaboration server, 2 Terabyte NAS (Ximeta) as seconf backup, 1Gb/s MSI ePower HD Network, 3xHD100, 1xHD200, 1xHD300, Panasonic LCD 55" TV, Sharp LCD TV, JVC LCD TV, Touchscreen LCD, PlaceShifter cu at http://www.dbuschek.de |
If you press shift-ctrl-F12 you launch up STV studio. You can create a menu item linking to the WebRadio widget on any of the menus. If you like I can create an addional STVi for installation on the original V5 STV and add that one to the plugin distribution zip file. When you import this stvi it will then also create a menu item on one of the menu's. On which menu do you want the Web Radio menu item to appear? |
media center -> online services i think this is a great place for online radio
Forgive me if I'm wrong, but doesnt the only available directshow shoutcast filter publicly available "Gabest SHOUTcast Source Filter - 1.0.0.1" not work correctly? Last I heard it had to be completely re-written. It currently has no buffer control; which means, streamed music skips or gets stuck pretty easily.
12 Capture Devices: Quad R5000's for Premium HDTV Cable & On Demand in HD + Quad HDHomeRun QAM Digital Cable Tuners + Hauppauge HVR-1800 for OTA ATSC + Dual DVBWorld DVB-S2 for FTA Satellite + Hauppauge HVR-950Q for loopback 5 Clients: HD300 (55" TV) - HD300 (46" TV) - SageTV Windows Client (46" TV) - 2 x Placeshifter clients |
Okay, I installed it and it WORKS! Thank you!! However, could you please add a SageTV STOP command before starting to stream? Currently, the web radio will stream audio regardless if there's TV in the background or not. The result is webradio and LiveTV (in background) at the same time! You can easily test this by enabling the following SageTV options:
Video Menu Option: - Display Video on Menus= Always - Video Menu Style= Background Hopefully, this will only take a couple of minutes to add. If you don't want to add this to the STVi, could you please explain how to manually do this in Studio? Thanks a million! -Michael
See attachment. Later I will add this to the distribution zip file on the download page. note You need to install the complete zip contents to get working Web Radio!! enjoy |
WMA streams
I would also like to play Windows Media Streams, common for commercial radio stations. See http://a553.l2004941821.c20049.g.lm....eflector:41821 for example
Any chance of adding this functionality? I already have the Windows Media plugin installed. |
What version of sagetv will this plugin work with? I am still running version 4.1.x
Great job koelec!
Just installed without any problems.My Online Services menu is almost full now. Weather Web Radio News Feeds IMDB Search Only one slot to go!
BruenerXII |
wow it works with my laptop client, but not with my mvps..
Great Addition to Sage!
Yes, you should be able to stop stream 2 ways... stop button on remote and it needs to stop automatically when you switch to TV or any other Media functions.. except Photo viewing.
Server: Dual Tuner: PVR-150MCE/PVR-250MCE/SageTV v5.02/Asus Pundit-R 2.4GHZ/512MB DDR RAM/250 GB Maxtor HD (8MB Buffer) External Seagate 400GB HD via USB 2.0/Onboard ATI 9100 using SVIDEO TV-Out/Nvidia DVD decoder/Actisys 200L IR Blaster (Dish receiver) USBUIRT (DirectTV receiver)/Lite-On 4X DVD-R/RW/Windows XP Pro SP2/Adesso Mini IR Keyboard w/integrated mouse/Tivo "Peanut" Remote via USBUIRT/Dish Network Model 301/DirectTV subscriber/Webserver Plugin v2.8 Last edited by cmaffia; 06-10-2006 at 05:39 AM. |
Does not work with Placeshifting.
Says: Error: Unknown Internal Screen "WebRadio"
Server: Dual Tuner: PVR-150MCE/PVR-250MCE/SageTV v5.02/Asus Pundit-R 2.4GHZ/512MB DDR RAM/250 GB Maxtor HD (8MB Buffer) External Seagate 400GB HD via USB 2.0/Onboard ATI 9100 using SVIDEO TV-Out/Nvidia DVD decoder/Actisys 200L IR Blaster (Dish receiver) USBUIRT (DirectTV receiver)/Lite-On 4X DVD-R/RW/Windows XP Pro SP2/Adesso Mini IR Keyboard w/integrated mouse/Tivo "Peanut" Remote via USBUIRT/Dish Network Model 301/DirectTV subscriber/Webserver Plugin v2.8 Last edited by cmaffia; 06-10-2006 at 06:25 AM. |
Also, one more bug found... When sageTV goes into sleep mode in the Windows System Tray, the music doesn't stop!
Thanks for all your hard work! EDIT: Actually, this isn't a bug, I could consider it an option ![]() Quote:
Okay, I installed it and it WORKS! Thank you!! However, could you please add a SageTV STOP command before starting to stream? Currently, the web radio will stream audio regardless if there's TV in the background or not. The result is webradio and LiveTV (in background) at the same time! You can easily test this by enabling the following SageTV options: Video Menu Option: - Display Video on Menus= Always - Video Menu Style= Background
12 Capture Devices: Quad R5000's for Premium HDTV Cable & On Demand in HD + Quad HDHomeRun QAM Digital Cable Tuners + Hauppauge HVR-1800 for OTA ATSC + Dual DVBWorld DVB-S2 for FTA Satellite + Hauppauge HVR-950Q for loopback 5 Clients: HD300 (55" TV) - HD300 (46" TV) - SageTV Windows Client (46" TV) - 2 x Placeshifter clients Last edited by mkanet; 06-10-2006 at 01:09 PM. |
![]() -drin |
Drin, you guys might consider working together on making one, really nice Internet Radio plugin which supports Windows Media Streaming.
Currently, I'm VERY happy with what he has released so far. Surprisingly, it works perfectly... all except for a couple of very minor issues - Send STOP command to SageTV (before the streaming starts) - Send STOP to Internet Radio (when sageTV sleeps) Quote:
-drin |
| Display Modes | |
| Plugin: Web User Interface for SageTV 2.2-6.6 (V2.25 18 Sep 2009) | nielm | SageTV Customizations | 2606 | 04-18-2013 10:11 AM |
| STV: Cayars17 Ultimate STV (Release 17 - Jan 18) | Cayars | SageTV Customizations | 3664 | 12-13-2005 04:35 PM |
| Comskip - STV import module possible??? | briands | SageTV Customizations | 7 | 01-02-2005 03:25 PM |
