Old 06-30-2006, 06:26 PM
srothwell's Avatar
srothwell srothwell is offline
New Wireless MVP vs. Old MVP with Bridge
Anyone know if buying an ethernet wireless to wired bridge would work just as well as buying a new wireless MVP?
I've got an MVP lying around and buying a $60 bridge is a lot cheaper than a $160 new wirelss MVP.
thanks,
Stacy
Old 07-16-2006, 07:54 PM
bowtie1 bowtie1 is offline
I use a wireless bridge without an issue (802.11g).
Old 07-23-2006, 11:42 AM
dbullock dbullock is offline
I have both wireless and wired MVP's. I have found it much better to use a wired MVP and a bridge. It's also cheaper! I picked up 4 CompUSA G AP's for $15 each. (They are no longer on sale but are only $30 now).
I like the idea of separate wireless devices since they can easily be replaced with N's in the near future.
Dan
Old 07-23-2006, 12:25 PM
walts81 walts81 is offline
Yes, I have a G router in my basement and a wired MVP with wireless bridge 2 floors above and it works flawlessly. However, I have a wireless MVP only 1 floor up and I've only gotten it to boot into Sage twice. Once I get it to boot, it works fine until it's shut off, or I use my microwave. Then it takes a miracle to get it back (and that's with the latest mvp.bin file).
- Josh
Server: Win7 x86, SageTV v7 beta, XBMC, AMD 5500+, 2GB RAM, 80GB hdd (Windows), 4x 500GB hdd (recordings), ATI HD3850, onBoard SPDIF out, HVR-1600, HVR-2250
Client 1 & 2: 50in Samsung DLP, 34in Insignia LCD, nMedia HTPC180, WinXP Pro SP2, SageTV Client v7 beta, XBMC, AMD XP2800, 1.5GB RAM, 80GB hdd, ATI HD3450, built-in audio, Firefly
Old 07-23-2006, 09:58 PM
stevech stevech is offline
Dan
I was at a conference last week - speaker was IEEE 802 task chairman. Said schedule as of now is to publish 802.11N in late 2007. Those pre-N products have jumped the gun a bit.
Old 07-23-2006, 10:01 PM
- Josh
With a bridge you can also, on many, use a directional antenna with gain.
Doggone microwave oven, if it has a leaky door gasket (yikes) will throw RF all over the 2.4GHz band modulated by 60Hz. If you arrange for a strong signal (like -75 or better (less negative, closer to 0), the oven's interference will lessen. You can also try using a different channel (on the Router), from 1, 6 or 11 in the US.
As you probably know, most any cheap W-Router can be configured as a bridge.
