Old 10-12-2006, 01:44 PM
rdefino rdefino is offline
Any advantage to using XP 64bit
I'm looking at building my nexted client and was wndering if I should use 64bit XP over the regular XP. Any reason why I should, or shouldn't?
SageTv server: 2008 64 BIT R2, Asus MN2-E, AMD dual core 4200, 4gb ram, Promise raid 5 8TB, 80gb Sata boot drive w/OS, 2/ dual tuner HDhomeruns, HD-PVR
3/HD-100's, 1/HD-200
Old 10-12-2006, 01:46 PM
I tried it, got stuck when I went looking for a IR sensor that had 64-bit drivers. Otherwise everything ran fine.
B
Old 10-12-2006, 01:57 PM
Mark SS Mark SS is offline
Lack of drivers is the big shouldn't.
Old 10-14-2006, 03:52 PM
rnadeau's Avatar
rnadeau rnadeau is offline
64 bit sofware support
Beyond TV supports 64 bit
Old 10-15-2006, 01:47 AM
nielm's Avatar
nielm nielm is offline
Funny then that it is not mentioned on their 'supported hardware/software' page. and the forum posts I found state that it does not.
