| SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here. |
As the title says, version 6.2 now supports using themed graphic sets.
When you first start SageTV, the default graphic theme set will load. To change the theme, go to Setup -> Detailed Setup -> Advanced -> Select the UI Theme. There are 3 themes included:
Choose the theme closest to the resolution you use most often. Themes are located in the <install dir>\SageTV\STVs\SageTV3\Themes directory, with the names of the themes determined simply by the names of the subdirectories in that location. The Themes\Standard SDTV directory contains some new UI images, a theme preview image, and the full theme.properties file. That properties file contains some settings for various things such as the offset path from the STV file to the full set of weather icons, text colors, and so on. Creating a new theme To create a new theme, simply create a new directory under the <install dir>\SageTV\STVs\SageTV3\Themes directory, using the name of your new theme. You can change one or more UI image files and you can create a theme.properties file to change one or more properties. If an image file or a property setting is not found, the one from the default theme will automatically be used. Exceptions: The tvicon_anim png files must be a full set of 8, #0-7. If you change the weather icons, you have to provide a full set and use theme.properties in the custom theme directory to specify the offset path from where the current STV is located to the weather icons. New graphics are being put in the theme directories, but those are not the only images you can place in your own theme -- you can change almost any image found in the <install dir>\SageTV\STVs\SageTV3 or "Standard SDTV" theme dirs. When loading a theme, each image is searched for by checking the current theme dir, the default theme dir, then the STV's dir. Notes There are some images in the <install dir>\SageTV\STVs\SageTV3 directory that are not used by the current default STV. You can enable debug logging & check the log to see a list of images found when you load a theme. Since this is a beta, there is still work being done on the menus and graphics. Theme settings in the default theme sets may be changed at any time. - Andy
SageTV v7.1.9 is available here. - Read the SageTV FAQ and PDF User's Guides for SageTV V7.0 & SageTV Studio v7.1. - Hauppauge remote help: 1) Basics/Extending it 2) Replace it 3) Use it w/o needing focus - HD Extenders: A) FAQs B) URC MX-700 remote setup Note: This is a users' forum; see the Rules. For official tech support fill out a Support Request. Before you ask: no, I can't say "when".
Wow, cool. BTW I like the look of new default theme. It looks more polished than in the past. Good work Opus4.
![]() - Andy
So will each STV have multiple themes...for different resolutions? Are STVs supposed to be the guts and the themes the Eye Candy?
And, if someone wants to release a theme targeted to a specific single resolution, they can do that; there is no requirement to provide multiple resolutions. You could load any theme while using a different resolution & the images would be resized as needed. But, for something like the MVP, you are better off using a theme made for its output resolution. (i.e.: native sized images are faster, so that is why there are multiple sets in the installer.) Quote:
The STV provides the functionality and UI layout. (It obviously needs a set of images for it to work, unless it is designed to use no graphics for some reason.) You can change lots of stuff in the STV while simply using the existing images in the default theme sets. Similarly, if you are happy with the default STV's layout & functionality, but you want a different look, create a replacement theme and use that instead. As I described above, you can change everything in a theme, or just the few images you want to be different. Finally, each UI can use its own theme w/o affecting any other UI. If you want each of your MVPs, Placeshifter clients, or SageTVClient systems to have a different look, all you need to do is select the theme you want to use in each location. Note: when changing a couple images for the default theme, make a new theme & use that one, don't just replace the original image. If you replace an image in one of the default theme dirs, it will get overwritten when you install the next SageTV upgrade. - Andy
THX!!
As someone who was vocal about sage's need for themes separate from the stv process, I really have to say thank you for this. Unfortunately I am hesatant to mess with the success im having with 6.1.9 so I will probably wait till 6.2 comes out of Beta to take advantage.
Nick |
Just installed this beta yesterday and liked this feature! Great work!!
Sage Server: Antec Solo, Seasonic S12 430W, AM2 3800, Gigabyte GA-M61P-S3 Mobo, XFX 7600GS 512MB, 2GB DDR2 800, 3 TB SATA, Hauppauge HVR1600, HDHR, indoor antenna, Win 7 Ultimate, MCE05 remote. Sage Client: Foxconn NT330i Intel Atom Dual Core, 1 GB DDR2 667 RAM, Windows 7 Ultimate. |
New in v6.2.7
Update for version 6.2.7: Many of the background color area fills have now been themed.
The theme.properties file in the "STVs\SageTV3\Themes\Standard SDTV" directory has color and alpha values defined for various types of color-filled areas. - Andy
I think I forgot to mention these changes for v6.3:
Help with Theme
I've created my first theme and uploaded to share it with others. See it here I am looking for some help however. The OSD doesn't seem to allow its background to be themed, so either I'm doing something wrong or something else is going on that I don't understand. I know very little about Studio, but it appears this is linked to the LiveTVOSDTheme. If you take a look at the two images I've attached, you can see that the OSD background is still the default background color. Any help or guidance would be appreciated.
Sage System: SageTV 6.3 | AMD AthlonXP 2200+ | Biostar M7NCG400 nForce2 w/Svideo and SPDIF out | 1GB DDR400 RAM | Hauppauge PVR-150 | 250GB Seagate | Nvidia ForceWare 84.21, PureVideo 1.02-223 | Gyration Wireless Combo |
The playback OSD has not been themed yet, since it has not been overhauled yet.
Andy, by your 'yet' statements I understand that to mean it will get done eventually. Do you think we are looking at a few months, or next year's radar? Just a ballpark guess would be great!
Thanks! -PGPfan
Sage Server: Gigabyte 690AMD m-ATX, Athlon II X4 620 Propus, 3.0 GB ram, (1) VistaView dual analog PCI-e tuner, (2) Avermedia Purity 3D MCE 250's, (1) HD-Homerun, 1.5 TB of hard drives in a Windows Home Server drive pool, Western Digital 300GB 'scratch' disk outside the pool, Gigabit LAN Sage Clients: MSI DIVA m-ATX, 5.1 channel 100w/channel amplifier card, 2 GB ram, , (1) Hauppauge MVP, (1) SageTV HD-100 Media Storage: unRAID 3.6TB server |
| Display Modes | |
| Intel Onboard Graphics - Image Quality? | Mahoney | Hardware Support | 6 | 02-08-2007 12:53 PM |
| Video Card Info | mike_15 | Hardware Support | 0 | 01-16-2007 06:22 PM |
| Decent PCI-e Graphics Card for SAGE under £75 | mrcandu | Hardware Support | 1 | 10-17-2006 02:48 PM |
| STV custom graphics | Bohica | SageTV Customizations | 6 | 10-13-2006 06:10 PM |
| No perfect graphics card yet? | TheraEdge | Hardware Support | 18 | 12-05-2005 09:17 PM |
