Old 11-01-2007, 09:13 PM
joe123 joe123 is offline
SageTV 6.2 Pauses During Playback
Hello.
I have had this problem since 6.x and I just upgraded to 6.2 thinking that it would fix the problem, but it is still there.
Every once in a while, like every 20-30 minutes or so while watching a recording, the image/sound freezes for about 8-10 seconds and then resumes.
I am using wired MVP, all of my 8 drives are 64k formatted and I run defrag every month or so.
The pauses happen when nothing else is running on my SageTV. Farily fast system - dual Intel CPU, 1GB of memory.
Any guesses what is causing the pauses?
Old 11-02-2007, 03:34 PM
rfutscher rfutscher is offline
I had a problem where playback on my two clients would pause every so often. They would pause at different times while watching the same show.
I ran Task Manager and discovered that network activity would stop when there was a pause.
I reformatted my record drive, just to make sure it was formatted correctly.
I found the write catch for the drive turned off. I turned it back on.
I downloaded and installed the latest network drivers.
I added a second drive.
I installed the newest drivers for my video card.
I only have slight problems now when there are three recordings and a live playback going at the same time. I don't think it was any one thing that was the total cure.
With four tuners going and a client, fragmentation should not be a problem. The drive heads have to move anyways to service all five buffers.
Originally Posted by joe123 View Post
Hello.
Old 11-05-2007, 10:58 AM
I have done all of those steps except for the using the latest network driver from Windows update, so I will do that and see.
Do you have your disks to spin down after x minutes? I have 8 drives and I have them spin down after 15 minutes of non-use. If I leave them all on, the systems builds up too much heat.
Old 11-05-2007, 11:12 AM
A couple more questions if anyone knows with regards to the Network parameters:
On my Win XP VIa Rhine Fast Ehternet Adapter Properties, I have the following options set:
Receive Buffers: 64k
Transmit Buffers: 64k
Flow Control: DISABLED
Shouldn't the flow coltrol be Enabled? Other option is "Hardware Default"
What about the Receive / Transmitt buffers sizes ok?
Joe
Old 11-05-2007, 06:55 PM
I used the drivers from the Realtek site for my NIC. The windows download drivers made the problem worse.
No, I do not spin down the drives.
Playback Stutters, Pauses, Speeds up, then it's fine? tangfj SageTV Software 23 03-22-2006 09:54 AM
Playback Error Capture Error in playback: TheraEdge Hardware Support 2 02-07-2006 03:36 PM
Stuttering playback or pauses in playback kny3twalker SageTV Beta Test Software 2 05-06-2004 08:10 AM
