Go Back   SageTV Community > SageTV Customizations > SageTV Customizations
Old 03-21-2008, 06:48 PM
mkanet's Avatar
mkanet mkanet is offline
Send a message via Yahoo to mkanet
I watched my first ripped Blu-ray movie on SageTV
This is probably not really a big deal, but I just watched my first Blu-ray movie (on SageTV). The only thing I did was rip the movie to disk and pull out the unwanted audio streams using a remuxer... then drop it in my Imported Videos folder.
This was just a test to see SageTV playing back Blu-ray's newest format: H.264 AVC.
12 Capture Devices: Quad R5000's for Premium HDTV Cable & On Demand in HD + Quad HDHomeRun QAM Digital Cable Tuners + Hauppauge HVR-1800 for OTA ATSC + Dual DVBWorld DVB-S2 for FTA Satellite + Hauppauge HVR-950Q for loopback
5 Clients: HD200 (55" TV)- SageTV Client (46" TV) - 3 x Placeshifter clients
Old 03-21-2008, 06:55 PM
Slipshod's Avatar
Slipshod Slipshod is offline
What did you use for the ripping and remuxxing? I'll be embarking on this shortly - now that the format war is basically over and BD+ is R.I.P.'d
SageTV V6.6.2 (WHS), SageMC 16x9 6.3.9b...can't remember
Server: WHS with Xeon X3350, 4GB ECC, ASUS P5BV-C/4L, recording into a 4.6TB Drive pool
Tuners: 4 (2x HDHR)
Clients: 1x HD200, 2x STX-HD100 Extenders, 1x Placeshifter
Hulu/Netflix via PlayOn
Old 03-21-2008, 07:30 PM
mkanet's Avatar
There's only one app that rips BD... that's AnyDVD-HD. You basically press the rip button and it puts it on your hard disk.
I'm using a free tool for remuxing... tsMuxeR
The only drawback to this method of watching blu-ray is you lose all the blu-ray menus and extra features.
Old 03-21-2008, 09:11 PM
mikesm mikesm is offline
Does it work on the extender?
Server: Sage 6.5.9 - X2 3800+, DFI NF4 MB, 1 GB, 300 GB HD (system disk), NV 7600GS, - Windows XP SP2
Client 1: Sage 6.5.9 - E7200, Abit IP35 Pro, ATI 4850 with HDMI connect to Denon 3808CI and Sony A3000 SXRD TV
Client 2: HD200 connected to Denon 3808CI and A3000 SXRD TV
Client 3: Media MVP to 15" Toshiba LCD
Client 4: HD100 connected to Samsung 23" 720P LCD
Client 5: HD100 connected to Vizio VX37L
Old 03-21-2008, 09:16 PM
mkanet's Avatar
I dont have an extender. Maybe someone else can try. My guess it yes. The extenders have the same media playback capabilities.
Old 03-22-2008, 04:26 AM
Lucas Lucas is offline
Mkanet that's great news. Can you please post the steps you did in TSMuxer?
Are you outputing .ts or .mkv?
Server: C2D, 3Gb RAM, 1xSeagate LP 1.5TB Recording HD, 8TB Green HDs for Videos, PVR-250, PVR-USB2, 2xCinergy 2400i DVB-T, 2xTT DVB-S2 tuners, FireDTV S2
HD200 connected to Projector, HD100 connected to 46" LCD TV, HD200 connected to 42" Plasma TV, Media MVP to 29" SDTV
Old 03-22-2008, 11:44 AM
mp328 mp328 is offline
also are u sure ur getting the 5.1 output correctly thru sage using .mkv container??
all my blu-ray rips using .mkv work in sage, but the 5.1 is not working correctly. if i play the files in zoomplayer i get a completely "different" sound then in sage. sage sounds more like stereo then 5.1 to me
Old 03-22-2008, 03:53 PM
mkanet's Avatar
If you try TSMuxer, you'll know there isnt really much to it. You just load the file and uncheck the audio and video streams that you dont want; leaving only the video AVC stream and ac3 English streams. It super easy. I'm outputing in .ts format.
Old 03-22-2008, 03:56 PM
mkanet's Avatar
Im saving as TS. I dont have 5.1 audio. So, I dont know for sure. My guess is with tsmuxer saved as TS (keeping the ac3 stream) you'll be fine.
Old 03-23-2008, 04:02 PM
Yes, ts-muxer plus anydvd-hd is a great combo. You don't get menus and such, but most people don't care that much about that. And it's just easier than trying to integrate powerdvd etc...
Old 03-23-2008, 05:36 PM
tmiranda's Avatar
tmiranda tmiranda is offline
I've yet to get smooth blu-ray playback on the extender. I've tried VC-1 encodes and H.264 encodes to no avail. On some rips I get choppy video and on some I get no video at all. I'm still trying to narrow down the issue to see if it's a ripping problem, a network problem, or a Sage problem. Audio is another issue altogether, but .ac3 seems to work OK.
Somebody in another thread said he got smooth VC-1 playback using a .mkv container but that did not work for me. (I used tsRemuxer to demux and mkvmerge to put it in a .mkv container.) I've also tried .ts and .m2ts containers.
If anybody has had success I'd like to hear about it, I am looking forward to watching HD movies on my extenders
Sage Server: ASUS/Intel C2D based system w/4GB RAM. WinXP Home, Hauppauge PVR 150, Hauppauge HVR-2250 and an HDHR. Runs headless. Accessed via VNC when necessary.
Two HD-100 Extenders and one MVP Extender.
Old 03-24-2008, 11:36 PM
mkanet's Avatar
The playback smoothness is related to the extender's hardware and software that the extender depends on. I'm guessing you would get the same kind of performance playing it locally on the extender machine in Windows Media Player. There's a small chance it's related to network bandwidth. For example, I dont think you can play them back smoothly on extenders with 802.11G wireless.
I know that the http://www.sagetv.com/hd_extender.html (SageTV HD Extender) is designed to play these files too with appropriate hardware and software.
Old 03-25-2008, 12:22 AM
I know it's pretty easy. My first few tries resulted in a file I could not play in SageTV. I need to experiment further.
EDIT: After one more attempt I got a .ts file with 1080p H.264 which plays fine in SageTV Client with the PowerDVD 7.0 Decoders.
On the other hand the HD Extender sits there trying to load it to no avail.....
In my experience the only things, h.264 related that play well on the extender are 720p x.264 reencodes.
So one could use TSmuxer to get the .ts file for playback on an HTPC and if needed do a reencode down to 720p x.264 for the HD Extender.
Old 03-27-2008, 01:51 AM
chrisc983 chrisc983 is offline
mkanet, what blu-ray drive are you using to rip the blu-ray discs?
Edit: Also after you run the muxer program how big are the files left? How long does it take to rip the movie wih AnyDVD?
Sage WHS - Intel Q6700, 4GB, Norco 5 bay hot swap x2, WD Black(OS), 6TB (dvd, bluray, music, pictures, videos) LG Blu-ray player, HVR-1600 x2 OTA
SageMC 6.3.9b pre-release 23
HD200: 46" LCD & HD200:26" LCD
Old 03-27-2008, 03:12 AM
Pretty close to the original source files used. ie Many many Gbs
Old 03-27-2008, 07:43 AM
mkanet's Avatar
It's an LG Super-multi drive. It came with my PC. Works great. I've been using it for a year now.
Surprisingly, the size does get smaller after pulling out all the unwanted audio streams and/or misc video. I've only tried a couple of movies; and it went from approximately 27GB-->19GB and 25GB-->27GB
This process isn't really that quick; it takes about an hour or so for ripping and remuxing. Its only worth it for movies I care about and want to watch again.
Old 03-27-2008, 10:50 AM
Sorry for asking a stupid question but I just want to make sure before purchasing it but do I need a blu-ray burner or just the player to rip the movies? Such as the Sony BDUX10S.
Old 03-27-2008, 11:10 AM
mikejaner's Avatar
Send a message via AIM to mikejaner Send a message via MSN to mikejaner Send a message via Skype™ to mikejaner
MKANET, would you be willing to cut a 10 second clip from the movie? If so I could try it with the extender.
Mike Janer
SageTV HD200 Extender X2
Sage Server: AMD X4 620,2048MB RAM,SageTV 6.5.x ,2X HDPVR, 2x HDHomerun. 80GB OS Drive, Video Drives: Samba Share, Ubuntu Server with 5x1500 GB RAID5
Old 03-27-2008, 01:52 PM
mkanet's Avatar
You dont need a burner.
Old 03-27-2008, 02:01 PM
mkanet's Avatar
Hi Mike, sorry.. that's illegal. I only backup my movies just as a personal backup.
STV Import: SageMC MovieTimes Movie Listings v0.64 Morgan111 SageMC Custom Interface 417 08-11-2010 06:05 AM
transferring over my movie collection raoul SageTV Customizations 4 02-14-2008 03:45 PM
Number of times movie watched? lordmeatball SageTV Customizations 2 11-29-2006 08:03 AM
video starting in middle of movie garyellis SageTV Software 6 05-07-2006 07:24 PM
Malore Watched Bar tearing again zoundz SageTV Software 2 12-05-2005 11:16 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
