Go Back   SageTV Community > SageTV Customizations > SageTV Customizations
Old 10-16-2008, 05:53 PM
cncb cncb is offline
Arrow Utility: Vista Sidebar/Windows 7 Gadget
This is a Vista Sidebar or Windows 7 gadget that allows you to see what is currently recording and upcoming recordings in SageTV with a flyout that shows the recording schedule. It can be run on any Vista or Windows 7 PC networked with the Sage server but requires nielm's web server or the Jetty web server to function.
Download here.
Version 1.1 - Nov. 22, 2008
  • Added options to launch web server with or without login (IE can't handle login).
  • Now gets SageTV install/launch directory location from registry.
  • Option to show channel logos in schedule.
  • Split out settings into multiple pages.
Version 1.2 - Nov. 30, 2009
  • Fix URLs for Jetty web server.
  • Shows system message icons (requires Jetty web server). Clicking on icon opens web server system message page in browser.
  • Added option to include padding in start and end times.
  • Recording schedule now groups recordings by day and shows start and end times.
  • Clicking recording title opens web server recording details page in browser.
  • Recordings in progress are shown in red in recording schedule.
  • Multiple airings of same program are now all shown in schedule.
Version 1.2b - Dec. 09, 2009
  • Fix error when not showing padding in times.
Version 1.3 - Feb. 21, 2010
  • Correctly show system message alert status if reset (requires Jetty web interface v2.26).
  • Increase maximum number of displayed current recordings to 12.
Version 1.4 - May 5, 2010
  • Now shows upcoming recordings in gadget along with current recordings (can return to show only current recordings by unchecking "Show upcoming recs" Display option).
Old 10-16-2008, 05:59 PM
Brent Brent is offline
Aw man! Craig, don't tempt me into buying Vista just to play with this stuff.
Seriously though - a job well done! I've been wondering why we didn't see more of these sort of things for Vista in SageTV.
Brent - HTPC and all-around Gadget Fanatic
Geek Tonic Blog - Why Google Bought SageTV
SageTV Tips How-To's and News
- Follow me on Twitter
Old 10-16-2008, 06:06 PM
I created a gadget a while ago for JRMC so you could get a 2 for 1 deal if you buy Vista (assuming you still use JRMC, of course) .
Old 10-16-2008, 08:41 PM
fearless fearless is offline
Thanks, I love Vista gadgets ...
Tried installing it but getting a debug error at line 9 - Object Expected
I am unable to right click and select options to change the configuration details.
I am running Vista Business SP1
Regards
Old 10-16-2008, 08:57 PM
Sorry, I'm not sure what the problem is. I just downloaded and installed the file I submitted on the download page to make sure that it isn't incomplete or corrupted and it seems to be fine. I developed this on Home Premium but I would be surprised if they are not compatible. Maybe it is some kind of administrator rights issue?
Old 10-16-2008, 09:28 PM
Hmmm ... I will have another go at it when I get home tonight, it seems like the gadget just after installation straight away it tries to connect to a server and errors out.
I tried to edit the sage.js file and pre-populate my server details but once I edit the zip file I can't seem to be able to install the gadget anymore ...
By the way do you need to have Sage Client installed for this to work or is it only dependent on the Sage webserver?
Because I only have a placeshifter client installed on my laptop ...
Old 10-17-2008, 07:12 AM
It will try to connect right away but should fail gracefully until you have all your settings correct. All you need is the web server installed on your Sage server - nothing special on the "client". Maybe you should try to open/install the gadget file as an "administrator"?
Are you by any chance using this on a PC set up for a country other than the US? If so, I think you will need to rename or copy the "en-US" folder to one named for your locale.
Old 10-17-2008, 07:24 AM
bialio's Avatar
bialio bialio is online now
Very nice! Good work.
btl.
Server:Cooler Master Centurion, AMD Athlon II X2 (3.2GHz) 8GB Partiot DDR3, Win 7 x64, 3 HDHR, 1 HDPVR, 1 2250.
Clients:3 HD300, 1 HD200
PHOENIX 2.0 is rising...
Old 10-17-2008, 07:31 AM
Not sure if this article would help you at all but just in case...
Can you view the sage webserver from that PC that you are doing this on? Just wondering if there is a port you needed to have opened or something.
Old 10-17-2008, 12:56 PM
ke6guj ke6guj is offline
looks good.
One thing I saw, that some people may have issue with, is the that the password for the webserver is in clear text.
- Jack
Old 10-17-2008, 03:51 PM
ghostlobster's Avatar
ghostlobster ghostlobster is offline
Send a message via MSN to ghostlobster
Regards
Exact same issue here. I wsa able to be quick enough to get the config settings entered, but everytime I mouseover it, I get the error.
I, too, am running Vista Business.
Ghostlobster
Server: Athlon 3000+, 1GB RAM, 2 Hauppauge 150s, HDHomeRun, HD-PVR driving 3 clients.
Client 1 - Athlon 4600 x2, 2 GB RAM, ATI HD2600 XT
Client 2 - Athlon 4200 x2, 1 GB RAM, ATI HD2400 Pro
Client 3 - Athlon 4200 x2, 1 GB RAM, nVidia 8500 GT
Raleigh Computer Repair
Old 10-17-2008, 04:41 PM
briands briands is offline
Not a vista user... so I 'm not sure how these things work... would this be a way to finally take advantage of a small touch screen on a client machine? Use this on the touchscreen while having sage full screen on the primary display?
Old 10-17-2008, 04:45 PM
Yes, it stores the password and sends it in clear text so I would not recommend using it on a PC that is not on your local network.
Old 10-17-2008, 04:48 PM
Strange that Vista Business would behave differently. Are either of you using a non-US setup?
Old 10-17-2008, 04:49 PM
Regional settings are English Australia and tried to change to English US but the same thing is happening.
I managed in between the errors to click on the configure button and it is actually listing the active recordings but the moment I try and hover the mouse pointer over the gadget the error pops up again ... very strange.
I ran the ms debugger and it seems to be getting stuck at sage.html and I checked the permissions and made sure the files are not read only.
I am a member of the local administrators group and I have UAC turned off.
I also turned off all security in IE7 just in case.
I will keep trying
Old 10-17-2008, 04:51 PM
I don't think so. These are little gadgets that sit at the side of the screen. So they wouldn't really be feasible to use on a small touchscreen. This one also doesn't offer any control of Sage playback.
Old 10-17-2008, 05:16 PM
Interesting. Does it give an error when you mouse over any area of the gadget? In particular, can you try the upper right corner that is empty and doesn't use the "hand" cursor?
You could also try to copy the whole "en-US" directory and rename it to "en-AU" (in the "C:\Users\USERNAME\AppData\Local\Microsoft\Windows Sidebar\Gadgets\SageTV.Gadget" directory). Reboot and see if you get the same errors.
Old 10-17-2008, 06:06 PM
killervette killervette is offline
Nice gadget!!! loving it
Rack Server: WHS Intel Quad Core, 3GB RAM, 3 HD PVRs, 4.5TB Storage and growing.
Rack Server: Dual Core 2.0Ghz, 320GB - Home Automation/Security/SQL Server
Client 1: HD Extender on 42" Samsung 1080P LCD and 92" Epson 1080p Projector.
Gaming Rig:Q6600 Quad O/C to 2.8ghz, 4GB DDR2 1066 RAM, Geforce 8600GTS
Misc: Onkyo TX-SR705 Receiver, Netgear Pro Safe 16port Gig Switch, Cat6 cabling, Linksys WRT54G running tomato firmware
Old 10-17-2008, 06:43 PM
JerryB JerryB is offline
I like the gadget. Very nice, indeed. My only problem is that you've hardcoded the location of programs such as sagetvclient at "C:\program files\sagetv\sagetvclient.exe". To try to eliminate some of the issues with UAC, I don't install all my software into the default program file directory and SageTV is one of the programs that is not installed in this default directory. As a result, clicking on the gadget to launch a program such as the SageTVClient fails since the gadget doesn't find the program file at the hard coded location. Is it possible to add the SageTV install directory as a configuration option?
Jerry
Old 10-17-2008, 06:57 PM
Yeah, I was afraid of this. I was going to get the install directory from the registry but I didn't see any easy way to do this from the gadget. I could add the install dir as an option but that page is full (I would have to do something with multiple pages). In any case, in the meantime you can edit the "C:\Users\USERNAME\AppData\Local\Microsoft\Windows Sidebar\Gadgets\SageTV.Gadget\js\sage.js" in Notepad and edit the CLIENT_EXE string at the top.
SageTV vs. Vista Media Center Brent General Discussion 29 05-03-2009 03:01 PM
My Sage TV 6.3 Problems and Fixes (Long) tcsubwoofer SageTV Software 12 05-08-2008 07:35 PM
Vista Issue and my Solution jobe1022 SageTV Software 2 11-21-2007 10:46 AM
Any way to view SageTV as a sidebar gadget? SAGEaustin General Discussion 6 10-17-2007 07:56 PM
SageMC - Stop button causes AWTThread Hang Mahoney SageMC Custom Interface 7 10-25-2006 12:47 AM
