Go Back   SageTV Community > SageTV Customizations > SageTV Customizations
Old 04-07-2009, 07:44 AM
babgvant babgvant is offline
Arrow Utility: SageTV Registry Settings
SageTV Registry Settings is a simple GUI application that exposes all of the registry settings SageTV can use with a short explanation of what the setting does (as a tool tip).
The UI is dynamically driven from the included xml file, so future settings can be added easily.
bin
If anyone knows of any settings that aren't in the tool let me know and I'll add them.
babgvant.com | @babgvant | Missing Remote
Old 04-07-2009, 08:32 AM
jaminben jaminben is offline
This looks like it will come in very handy.
Nice job
Old 04-07-2009, 09:01 AM
pedz25 pedz25 is offline
Nice job
Agreed! Thanks for putting this together.
Old 04-07-2009, 09:12 AM
Brent Brent is offline
I played around with this app over the weekend - a great idea indeed!
I'm curious how to use this setting:
"Custom Demux GUID"
Brent - HTPC and all-around Gadget Fanatic
Geek Tonic Blog - Why Google Bought SageTV
SageTV Tips How-To's and News
- Follow me on Twitter
Old 04-07-2009, 09:24 AM
"Custom Demux GUID"
It's the GUID for an alternate demuxer filter. I've messed with it in the past, and it seems to work fine (in some cases better, at least before the new sage demuxer got stable) for recorded tv; but fail horribly (crashing the client in some cases) for live tv.
To use it, you'll need to get the filter's CLSID from GraphEdt or GraphStudio.
GraphStudio:
Old 04-07-2009, 02:36 PM
QueOnda's Avatar
QueOnda QueOnda is offline
Use Larger Buffers For Network Capture - Enables optimizations that help with network encoding file transfers by using much larger packet sizes (off by default, 1 enables it)
Does this help/hurt with HDHR recordings? When disabled what is the packet size? And Enabled what is the packet size?
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
Old 04-07-2009, 02:51 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
The Large Buffers For Network Capture setting only applies to network encoders (not the HDHR). It affects buffering on the output from the directshow capture device before it is sent to the network. Many capture devices output in 2K chunks; and that's not optimal for network transfers; so that option buffers them up and sends them as larger chunks (64k). It's not heavily tested though; which is why its not on by default. This setting would need to be made on the machine running the network encoder.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 04-07-2009, 02:53 PM
QueOnda's Avatar
OIC, Thanks for the explanation. Anyone have good experience with the Max java heap size greater than 512? I read in another thread someone put theirs to 1GB and had issues.
Old 04-07-2009, 05:14 PM
antplugger antplugger is offline
Does this work for Vista (32 and 64 bit) ?
Old 04-07-2009, 05:26 PM
It probably doesn't. But that's easy enough to fix.
Old 04-07-2009, 05:29 PM
Could you add an option for:
ui/enable_hardware_scaling_cache=false/true
Cheers
Old 04-07-2009, 05:33 PM
I mean it does work in x86, x64 probably puts the values in the wrong place
Old 04-07-2009, 05:37 PM
Cheers
it only does registry settings, although it would be cool if it could manage properties as well.
Old 04-07-2009, 05:39 PM
updated (same link)
Old 04-07-2009, 06:08 PM
Yes... yes it would be cool...
Old 04-07-2009, 06:31 PM
I was thinking it would be nice to have a tool that has all the hidden enhancements available in one place. Then when you have to re-install for what ever reason you could use one tool to set all those forgotten options.
Old 04-07-2009, 06:42 PM
agreed. I'll have to see if I can change sage properties through their api.
Old 04-07-2009, 08:36 PM
71_Cuda 71_Cuda is offline
I'm having good luck using 1 GB. In fact, I seem to be much more stable there. I upped from 256 to 512, then to 1024 (shows up as 1065), and I seem to have fewer random crashes. I tried 1 GB because I was maxing out 512, but I max out 1024, too. Still haven't figured out why. I had a posting about this issue related to accessing migrated dvr-ms files, but didn't get any real helpful responses. I haven't tried any higher.
Old 04-07-2009, 08:51 PM
alfi33 alfi33 is offline
Thanks! Great tool! How about adding an option to change the Numbuffers setting in the registry?
Old 04-08-2009, 08:04 AM
Last night's build included settings for the beta demuxer (is that what you're talking about?). If not, I need the key/value location.
SageTV, Directory and Registry? steingra SageTV Software 3 12-23-2008 10:52 PM
SageTV Client H264 Playback lags and can't find correct registry location for buffer pingmustard SageTV Software 0 12-17-2008 01:50 AM
Is there a registry value that holds the path to the SageTV Folder? evilpenguin SageTV Studio 5 01-03-2007 01:25 PM
I would like to reset all SageTV 4.0 registry settings back to the original defaults mkanet SageTV Software 3 11-14-2005 06:03 PM
for haup reg hack, make sure you check if registry settings exist for new version jw1248 General Discussion 3 10-21-2003 08:45 AM
