Old 04-09-2009, 12:33 AM
buymysoul buymysoul is offline
Video card required for WHS install?
I've been trying to set up SageTV on my Windows Home Server (WHS) and keep running into little roadblocks when recording TV.
At first I hadn't realized that I needed to have Directx 9 and Java installed...actually, I'm still not sure if those are actually required with a WHS install or not (I've seen some posts that imply otherwise) but I uninstalled SageTV, installed Directx 9 and Java and installed SageTV again. I can configure everything just fine but when I record a show it goes away after it is done recording. If I actually try to tune in a channel over remote desktop, I get a "no Signal" message. I did do a trial run with sage on a Vista box in the house and that worked fine.
I'm using an HDhomerun for QAM content but it dawned on me that maybe Sage still wants a video card to record? I feel pretty silly for not thinking of this ealier, I was just thinking about a pure digital stream from the HDHR, through Sage to my hard drive but maybe some video hardware is still needed?
Searching through the forums, I've seen lots of requests for a hardware list when someone asks for help so don't think this is just gratuitous:
WHS PP2
AMD Turion 2.0Ghz
2GB RAM
Drive Outside Pool formatted with 64k clusters
HD Home Run tuner
Thanks for the help,
Robin
Old 04-09-2009, 05:57 AM
Polypro Polypro is offline
While not required , I installed DX9 and Java as well, and got everything running on the server first...to me it's easier that way. On board video would be fine however, if you don't have a video card. It's playback that needs those items, not recording. A dissappearing recording would seem to indicate that the recording had a problem...probable with a mis-configured HDHR setup. Follow the HDHR setup again (remember to shut down Sage UI AND Service, scan with both tuners, check that you have a .scn and .freq for each tuner, etc...) and fix that "No Signal" error.
P
Old 04-09-2009, 11:45 AM
Actually, I don't have any onboard video either. On a lark, I removed the video card when setting up my WHS originally and the system still boots and runs fine (although I do get a beep from the bios griping at me on startup) so I leave it out to save a watt or two.
My original scan with the HDHR was before I installed Sage. And sage has been uninstalled and reinstalled a couple times since then...
I just installed VLC and I can tune in channels just fine with it. Well, I can see a picture. I am just remote desktoping into it after all. Doesn't that mean that the HDHR is configured correctly? When I setup and scan for channels with sage, it only selects channels that I have selected (with a check) in the HDHR scan.
Could you remind me where the .scn and .freq files are by default so I can verify they are there?
I figured the same thing about the video hardware but I wonder if having no GPU at all is a problem for Sage?
I guess I'll have to dig the server out of the closet and install a video card to see if that fixes the problem....
EDIT: So I should be able to watch live TV (at least marginally) with just remote desktop? Or at least I will see something other than "No Signal", right?
Thanks for your help.
Old 04-09-2009, 12:36 PM
Thanks again for the advice.
I rescanned again with the HDHR, rescanned with Sage and now things look like they are working.
I swear I had done that before but maybe installing Java and Directx since the last scan is what made the differerence.
I still can't watch live TV as I get an audio error in sage but since I don't have the sound enabled in the bios on the server that isn't a huge suprise.
recording tv, system requirements, whs
Is ArcSoft TME required for headless WHS server? bfb1963 Hardware Support 9 03-30-2009 08:08 AM
What is required to do a clean install of SageTV? Ralphjb SageTV Software 4 03-08-2009 08:35 AM
Can't use VMR9 on new video card install sonoman SageTV Software 10 03-15-2007 09:01 AM
Tuner card required? YvesAdeleHarlow SageTV Software 15 02-19-2007 12:22 PM
What Video Card and TV Tuner Cards are required for my setup? darrennye Hardware Support 0 01-01-2006 03:09 PM
