Watching other media files
Hi,
I have just tried, for the first time, to use Sage to play back imported videos. However, the test files I have copied over are not showing up, they are avi's and mkvs. I have searched to try and find posts giving details on how to import videos but I couldnt find any with basic information. Could someone please post some links so I can read up on what codecs are supported and also what else I might be doing wrong. Thanks, Simon. |
Do you mean the files aren't listed as part of the imported videos or what? If the files are in your video import dir(s), they should be getting imported when a new library scan is done. If you don't have it set to rescan periodically, you'll need to manually start a scan. If the scan is done, then check the extensions listed for this property: seeker/video_library_import_filename_extensions.
SageTV v7.1.9 is available here. - Read the SageTV FAQ and PDF User's Guides for SageTV V7.0 & SageTV Studio v7.1. - Hauppauge remote help: 1) Basics/Extending it 2) Replace it 3) Use it w/o needing focus - HD Extenders: A) FAQs B) URC MX-700 remote setup Note: This is a users' forum; see the Rules. For official tech support fill out a Support Request. Before you ask: no, I can't say "when".
| Display Modes | |
| MAC 6.40 Placeshifter won't unlock files after watching | srothwell | SageTV Beta Test Software | 2 | 04-25-2008 12:29 AM |
| Watching TS files?? | polen | SageTV Media Extender | 17 | 10-03-2006 02:28 PM |
| too many small files when watching LiveTV | steingra | SageTV Software | 7 | 10-29-2005 11:05 PM |
| Watching Sage MPEG files outside the program? | Bobz | General Discussion | 4 | 05-23-2005 09:42 AM |
| Saving Files when Watching LiveTV | tsg2513 | SageTV Beta Test Software | 7 | 01-25-2004 03:04 PM |
