Go Back   SageTV Community > SageTV Customizations > SageTV Customizations > SageMC Custom Interface
Old 03-27-2010, 11:00 AM
rtrski rtrski is offline
Having "Delete" difficulties in HD200 Guide options...
Hope this isn't a threadjack, as it's closely related.
Figured out getting to the Options screen in the Guide view on the HD200 (used as client, so I'm in the proper forum).
But what I can't for the life of me do is change the "channel entry width" - defaults to 0.18, I use logos not the listing names (e.g. WFAADT), so I want to shorten this to 0.13. (Other fields like # of columns or rows, font size, when you select the entry they open up pre-cleared so you just enter the number you want to update to...but not the column width for the channel entry.)
But while I can open the entry box for the field in the Options menu, I can't seem to use the Delete key toward the bottom of the remote to delete the "8" and replace. Also tried the "back" key on remote, the left arrow, etc. Left and right move the cursor position in the entry field, but delete still doesn't do anything....
This is using SageMC by the way, if that makes a difference. I can also find the setting for the epg channel width in my SageClient.PROPERTIES file but that seems to be the one for the server, not the HD200 extender.
Saw something to the effect that the remote has 'combo keys' - not sure where to find them either. Still looking so apologies if this is a dumb question.
Never mind....just tried every BLEEP key on the remote until one worked. For some odd reason, 'backspace' in entry fields was mapped to the STOP key on my remote. At least I got it corrected, but that's just odd. We'll see what happens when I try to program the Harmony next....also kind of odd the "Videos" button takes you to "recorded tv" screen, but maybe that's a SageMC thing.
Last edited by Opus4; 03-27-2010 at 01:11 PM. Reason: Post in the SageMC forum for all SageMC related issues/questions
Old 03-27-2010, 02:05 PM
I haven't used sagemc for quite some time, but i think STOP is equivalent to backspace.
Sage Server: Phenom II X4, 16GB RAM, Win7HP, 1x1TB (system/misc-imports), 2x750GB+3x2TB(recordings/media)
Sources: Two R-5000HD equipped ViP-211's for Dish Network, HDHR3 Dual for OTA
Primary Client: i3-530, 2GB RAM, Win7HPx86, miniITX H55 MB, 160GB laptop drive, Samsung HLT-6189S
Other Clients: Phenom II X2 545 w/8GB and HD6670 in Master Bedroom, MVP in kids play room
Old 03-28-2010, 08:19 AM
PLUCKYHD PLUCKYHD is offline
correct
"Delete" key doesn't bring up normal dialog freedml SageTV Software 0 05-18-2009 03:40 PM
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting maxpower SageMC Custom Interface 9 05-14-2008 09:44 PM
How can I prevent/delete Imported files listed in the "Search for Programs to Record" ke6guj SageTV Beta Test Software 4 10-10-2005 01:52 PM
Did anyone record "Medium" - bug caused Sage to delete it zz5 SageTV Software 21 01-12-2005 12:46 PM
Auto delete "record while you watch" files? HawkeyeLonewolf SageTV Software 19 09-02-2003 10:31 PM
