Go Back   SageTV Community > SageTV Customizations > SageTV v7 Customizations
  #101
Old 03-25-2011, 01:55 PM
In a perfect world, the S-E number order would be the same as the OAD order - but we know that isn't always the case... of course, in a perfect world, you'd have S-E numbers for everything also. Having the option to display S-E numbers if present would work well, but there's already a plugin to do so.. ;-)
Sage Server: Phenom II X4, 16GB RAM, Win7HP, 1x1TB (system/misc-imports), 2x750GB+3x2TB(recordings/media)
Sources: Two R-5000HD equipped ViP-211's for Dish Network, HDHR3 Dual for OTA
Primary Client: i3-530, 2GB RAM, Win7HPx86, miniITX H55 MB, 160GB laptop drive, Samsung HLT-6189S
Other Clients: Phenom II X2 545 w/8GB and HD6670 in Master Bedroom, MVP in kids play room
Old 03-25-2011, 01:59 PM
I don't use any plugins & I want to see the s/e numbers instead of ID numbers, so that's what it does now.
SageTV v7.1.9 is available here.
- Read the SageTV FAQ and PDF User's Guides for SageTV V7.0 & SageTV Studio v7.1.
Before you ask: no, I can't say "when".
Old 03-25-2011, 02:00 PM
There is possibly a more robust method possible.. but nothing would be foolproof. You could sort all the non-zero S-E numbers, and then insert the zero S-E numbers after the S-E having episode with the next older OAD... ;-) just trying to make work for you Andy... it may be the best alternative, though...
Old 03-25-2011, 02:06 PM
I already know how it could be done, but it would just add more processing time for very little, if any, benefit compared to simply sorting by orig air date. I'll leave that to a customization so you have something to do.
Old 03-25-2011, 10:53 PM
well, i won't be tackling it, though at the same time, I don't have any missing season and episode info (as I fix any missing parts with BMT or manual tweaking)... so i certainly wouldn't be caring one way or the other... but I wasn't the one concerned with the ramifications of the inconsistent sorting data.
Old 03-26-2011, 05:32 AM
davephan's Avatar
davephan davephan is offline
Why the code "5309"? Couldn't the code have been "1234" or "7243" (sage)? Is there a reason why "5309" was selected for the code instead of a number that would be easier to remember?
Dave
SageTV: LIAN LI PC-K58, Gigabyte GA-EX580UD5, i-7 950 3.06 gig quad LGA 1366 CPU, Zalman CNPS9700 CPU cooler 1366 bracket, Kingston 3 GB DDR3 1333 Mhz, PNY NVIDIA GeoForce 9800 GT 1024 MB, Corsair 750w PSU, Samsung 840 Pro 128GB SSD boot, 3 x 1.5 TB
Tuners: HDHR OTA, 2- HVR-2250 OTA, Colossus, USB-UIRT, HD DishNetwork
Extenders: 1-HD-300, 2-HD-200
Software: Windows 7 Home X64, Ghost 15, VideoReDo TVSuite 4 h.264, Playon (Netflix)
UnRAID 4.7 Pro: Lian-Li PC-G70B, MBD-X8SIL-F-O, i3-540, 16 TB
Old 03-26-2011, 05:45 AM
Dave
Maybe it was someone's favorite song.
"867-5309/Jenny" is a song written by Alex Call and Jim Keller and performed by Tommy Tutone. Jenny has been covered by a number of artists, including Everclear, Foo Fighters, Less Than Jake, Mötley Crüe, Green Day, Bracket, Crease, and the Goo Goo Dolls.
Old 03-26-2011, 09:50 AM
thomaszoo thomaszoo is offline
Thanks. Maybe the next time I need it I will be able to remember it!
Wayne
i7-870, Gigabyte GA-H57M- Micro ATX MB, 4GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 7,Ceton CableCard Tuner, 2 x HDHR, 2 x HD300 + 2 x HD100
Old 03-26-2011, 01:30 PM
samgreco samgreco is offline
And there were people all over the country that had that number that suddenly started to get all kinds of strange phone calls. Looking for Jenny....
The phone companies took the number off of their lists of available numbers. Don't now if any of them have ever started using them again.
Old 03-26-2011, 02:59 PM
A couple of years ago some had one "for sale" on e-bay.
http://articles.cnn.com/2009-02-02/e...?_s=PM:SHOWBIZ
Old 03-29-2011, 09:40 AM
The existing option to use the malore menus for "Custom Additional Airings" currently only applies to viewing the Future or Past airings for a show. This is being updated to cover the listing of all search results when the option is enabled.
Old 05-29-2011, 06:07 PM
graywolf's Avatar
graywolf graywolf is offline
Future Airings - Get the Channel Logo but not the Channel Number.
Is there a means to get the Channel Number (either with or without Logo)?
Old 05-31-2011, 06:23 AM
I don't understand the question.
Old 05-31-2011, 06:46 AM
graywolf's Avatar
ok. I'll try to explain better, if that doesn't work, I'll see about getting a screenshot tonight.
When you view Future Airings and the 2 pane Malore window shows up, on the Right-Side (I have as 2 rows height),
On the right hand side, I see the Title/Episode icons (m/f, 1, w, etc) date/time then the channel logo (ie. the "eyeball" for CBS, black circle with ABC in it for ABC channels, etc) but in my case, I have multiple ABC channels from different cities (local, NY, LA).
Is there a means of seeing maybe the Call Letters and Channel Number instead of the Logo?
Some shows my wife cares about WHICH station she is recording a show from or if the weather forecast is going to be bad, might want to record the NY station instead of local so as to avoid the "weather alerts" scroll bars or interruptions.
Also, another question I got asked about the Malore Menus:
For Future Airings, Scheduled Recordings, etc, is there a means to have Row Numbers? Wife is used to checking the row numbers to determine if there are stuff above/below or if she has wrapped around (V6). I have V7 on a Test box and trying to get WAF high enough for me to upgrade the Prod to V7.
Old 05-31-2011, 08:36 AM
Channel logos are always shown if a logo exists for the station. And, with the built-in logos, there is often a logo, though it can be somewhat generic for a network, such as the same image for all ABC stations.
You could, however, provide custom logos for each station, as described in Appendix B of the PDF manual. That would make it easier to distinguish between different stations for the same network.
There are no row numbers, but the scroll bars should show the relative position in the list & they wrap if the list has wrapped.
- Andy 19,000
Old 03-26-2012, 01:06 PM
les_bloom les_bloom is offline
Group by title and sort by date?
Hello,
I have been playing around with the 'upcoming movies' tool.
That tool uses the malore views.
In the view, I am grouping the movies by title.
When I do this, none of the sort methods seem to work other then sort by alpha.
For example, I change the sort method to by original airing date, and nothing changes in the display.
Does anyone have any info on this?
Les
Unofficial Secret Extra v5-6 UI Features Opus4 SageTV Customizations 257 07-25-2011 12:54 PM
extra timed recordings features? rsagetv99 SageTV Software 5 12-07-2004 01:36 PM
