Unfortunately, a whole lot of the .properties file options aren't well documented, or even documented at all (big HINT HINT!
), but I figured out how to get audio to work properly with the PulseAudio server that is the standard for modern GNOME, particularly for recent Ubuntu releases. Wrapping in "padsp" is not necessary.Close SageTV(Placeshifter), then open $HOME/.sagetv/SageTV.properties (or SageTVPlaceshifter.properties) in your favorite text editor and add the following line: Code:
audio_render=-ao alsa:device=pulse A more generic solution, which works for me (but may or may not work for you), is to tell ALSA to use its system-wide configuration to route sound output: Code:
audio_render=-ao alsa |
Thanks for this. It solved my problem, though I did not see this thread as originally posted, but was referred to it by another member in the Linux sub-forum. You should probably post this info there, as well ...
I have reported this problem with pulse audio to Sage as a bug a while ago. Great work on finding the solution. Did you posted it to Sage as a bug/resolution? They do not read every post in this forum.
TV: Samsung UN46D8000 Server: Intel Core i3 540, 4G RAM, Matrox G450, 70GB EXT3 encrypted software RAID1 system drive, 1TB XFS tv recording drive, 2TB EXT3 encrypted data drive mirror across 2 machines, 2TB EXT3 encrypted media drive mirror across 2 machines, CentOS 6 64 bit, Experimenting with DNLA servers 1Gb wired network Disconnected after G day[HD 100 Media Extender, Placeshifter 7.x, SageTV 7.x, HDHomeRun] |
Thank you for the fix!
It's been a while since I encountered problems like this. |
| Tags |
| alsa, audio, gnome, linux, pulseaudio |
| Display Modes | |
| Ubuntu 10.04.1 - Sage Server for Linux - Haupaugge 2250 | shugrue | SageTV Beta Test Software | 3 | 10-15-2010 01:28 AM |
| Linux SageTV OEM not recognising DVB-T HDHomeRun on Ubuntu 9.10 Server (64-bit) | milesbrennan | SageTV Linux OEM Edition | 14 | 05-21-2010 03:35 PM |
| Channel scan crashes on beta 7/ubuntu linux | bfgarcia | SageTV Beta Test Software | 0 | 05-21-2010 12:15 PM |
| Linux (Ubuntu 7.10) - Placeshifter font too long | ltitran | SageTV Linux OEM Edition | 9 | 04-09-2008 06:00 AM |
| Ubuntu 7.04 and SageTv Linux 6.1 | Box8489 | SageTV Linux OEM Edition | 7 | 06-01-2007 07:25 PM |
