| Batch Metadata Tools This forums is for discussing the user-created Batch Metadata Tools for SageTV. |
Batch Metadata Tools - Start Here
Well, I can finally say that I've completed the 4.x release of BMT, and I have the documentation to prove it
![]() Quick Start (alternate version) Short quick guide on installing/upgrading/updating BMT About BMT (alternate version) I recommend that everyone read this document, even if you've been using BMT for a while. I hope it helps explain the product and its close relationship with Phoenix. BMT User Guide (alternate version) User Guides are tough to write. I've refrained from writing one because the product was changing pretty fast. But now, I think that it's fairly stable. While you might now read the entire user guide, please check the table of contents, to see if there are things that may catch your attention. If you have trouble opening the links, then try the alternate versions. The alternates are not well formatted, but they should work, in the event that the 'formatted' version does not. I hope both of these documents are of help to the community, since they both took way too long write. Now I can get back to doing what I do best, write code. Videos / Tutorials Youtube Channel Enjoy
Batch Metadata Tools (User Guides) - SageTV App (Android) - My Other Android Apps - sagex-api wrappers - Google+ - Phoenix Renamer Last edited by stuckless; 05-31-2011 at 05:43 PM. Reason: Add 'Relocating Fanart' tutorial |
Just a bump, to let people know that I've posted "formatted" versions of the documents. The original links were horribly formatted from google docs, but they should now look ok. But if you have issues accessing the mian links, then use the alternate links (which are unformatted)
Batch Metadata Tools (User Guides) - SageTV App (Android) - My Other Android Apps - sagex-api wrappers - Google+ - Phoenix Renamer |
There was a permissions issue with the Google Docs Link. That should be resolved now. You should not need a google account to simple view the document.
I started to get so many requests to "share" the document, that I thought people were wanting to edit them It turns out, people just wanted to see them
Excellent work, Sean. Being a fellow developer I know how hard it is to write doc when you could be doing something else. I haven't used BMT in a while and it looks like the web UI has come a long way.
Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun. Extender: STP-HD300, Harmony 550 Remote, Netgear MCA1001 Ethernet over Coax. SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client, Java 1.6. Plugins: Jetty, Nielm's Web Server, Mobile Web Interface. |
BMT is fairly stable right now, in terms of features, so hopefully the documentation will remain relevant for at least a few months
Thanks a lot Sean. Although I am "fairly" comfortable playing with BMT, most of my successes came after numerous failures. Reading the docs have helped me to solidify those things I know and filled in the gaps of those that I don't.
Really appreciate your time. Grant Last edited by OneOfMany; 12-13-2010 at 10:02 AM. Reason: spellung |
Ok.. I'll bite lol..
1) Often you will mention to "touch" the file to allow metadata to be refetched on the media item. Somewhere a long time ago, in one of your posts you recommended installing the "touch" command and registering it to show up when a file is "right-clicked" in Windows Explorer. This has really helped when correcting stuff. Maybe a quick blurb on where to get, how to install, and how to use. 2) I have many media files such as home movies, music videos, web downloads that have no "official" metadata. I like to create my own manually, including creating the appropriate fanart directories. Some I set as TV-series, some as Movies. It sort of "completes" the vids ![]() Maybe a quick note on doing this. Grant |
The Touch.exe I downloaded was from a post here with instrcutions from babgvant
http://forums.sagetv.com/forums/show...exe#post368782 The direct link to the file is http://www.codeproject.com/KB/applic...touch_win.aspx To install. Extract file. Save the touch.exe to any folder. Note that moving this file after being registed/installed will cause it to no longer work. Use a text editor such as Notepad to creat a new file. Copy the text provided in the post. Edit the last line to your correct path to the .exe file. Save file as touch.reg in the same directory as your touch file (can be anywhere, but just makes sense) Right-click on the touch.reg file in Explorer and choose Merge. This will add the entries to your registry. Not sure if a reboot was needed, but right-clicking on any file will provide a "touch" option on any single or group of files selected. This will set the date/time to current. |
Typo???
(on the "About BMT" link) "" BMT is not associated with SageTV in any way, so please to send support related questions, regarding BMT, to core SageTV employees...." You mean "... don't send...to Sage Employees..." Right? Last edited by russellnewman; 12-23-2010 at 01:33 AM. Reason: left out last line |
hehe - it is a typo... it's been fixed, and thanks for pointing that out.
NoSuchMethodFound sagex.pheonix.metadata.automaticMetadataVisitor
I used to use MetaDataTool.jar in order to populate my video files on my media center with Season and Episode numbers
I recently had to re-install the system on win7, and I got sage7 to go with it, and of course MDT no longer worked - sadly.. cause it was great =) I instaled the new MetaDataTool, and BMT and any others that asked for "update" on the SageTV plugins screen - but when I try to run the metadatatool on any media I get NoSuchMethodFound sagex.pheonix.metadata.automaticMetadataVisitor.<init>{Lsave/pheonix/...} That looks to me like I'm missing a library or have an out-of-date library or something else. What I want to do is to run MDT.jar from the command line and get information on Season and Episode number, based on the title and show. Can anyone help me to get this back on its feet? |
Is quite OK - actually I went and looked up the tvdb API and made myself my own little episode-season metadata information grabbed for my media center =)
I find the problem the bmt command line as well.... It'll be fixed in the build, but sounds like you won't need it now
well I thank you for taking the time and for making the awesome BMT =)
BTW Sean.
The "you'll only see this message once" about the new manual, etc, shows every time I load BMT. |
The setting for this is stored in a cookie... do you have session based cookies? Maybe I'll look at doing this a different way.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| nyplayer |
| Display Modes | |
| Feedback on BMT - Batch Metadata Tools | Brent | Batch Metadata Tools | 7 | 11-15-2010 09:25 PM |
| Warring metadata tools | davidk21770 | SageTV v7 Customizations | 1 | 06-09-2010 11:07 AM |
| STV Import: Batch Metadata Importer Tools for Default STV | Tiki | Batch Metadata Tools | 23 | 05-03-2010 09:52 PM |
| Batch Metadata Tools new releases subscription thread | stuckless | Customization Announcements | 18 | 02-17-2010 08:27 PM |
