| Batch Metadata Tools This forums is for discussing the user-created Batch Metadata Tools for SageTV. |
SageTV Show Title Doesn't Match BMT Show/Fanart Title
I am having an issue that has been plaguing me for a while. As the title of the thread says, my SageTV show title and BMT show/fanart title do not match in some cases. This happens mainly (perhaps exclusively) on shows that I have added to my MediaTitles.xml file. For example, the show Super WHY! is listed as "Super Why!" in the Sage EPG and creates a file that looks like "SuperWhy-...". So I have a match entry in my MediaTitles.xml that fetches the correct show data based upon the file name. And it must be working because when I go into the BMT web interface and click on the show it shows "Super WHY!" for the Fanart title and "Super WHY!" for the show title and has all of the correct metadata [see BMT-title-03.png]. However, some of the shows in the BMT web UI are listed under a "Super Why!" grouping and some are listed in a "Super WHY!" [see BMT-title-01.png] grouping (not sure why some are fine and others are not). Likewise in SageTV. This means that SageTV is actually treating these as 2 separate shows.
Recently, this happened to me with The Amazing Race as well. The EPG show title is "The Amazing Race: Unfinished Business", but I have it setup to find "The Amazing Race" on tvdb. It works properly and returns all of the correct metadata. The show and fanart title are "The Amazing Race" in the BMT info but are filed under "The Amazing Race: Unfinished Business" grouping. To make matters weirder, I tried to 'force' BMT/Sage to update the show title by simply clicking on the "Save" button in the BMT editor. This seemed to temporarily work, but the next day the shows were back to being filed under their EPG name. The metadata in BMT still looked fine. Hope that makes sense. I have attached some pictures that will hopefully help. Thanks.
Server: SageTV Media Center 7.1.19, Windows XP Pro (SP3), Pentium D, 2GB RAM, (1) Hauppauge HVR-2250, (1) Hauppauge HVR-1600, 1 TB of recording space Client: SageTVClient 7.1.19, Windows 7 x64, Acer AspireRevo r3610, Intel Atom, nVidia ION, 2GB RAM, HDMI out to Samsung LN46C630 46" LCD Extender: STP-HD300, beta firmware "20110506-0", HDMI out to LG 37LD450 37" LCD |
I'm not sure what would be causing this issue. I can see cases where BMT will set a different fanart title than the main title. But bmt doesn't typically overwrite items that have metadata, so i don't know why your titles are being reset.
Batch Metadata Tools (User Guides) - SageTV App (Android) - My Other Android Apps - sagex-api wrappers - Google+ - Phoenix Renamer |
Any guesses as to what this could be? My understanding is that the value in the "Show Title" field in BMT should be the exact same as SageTV's show title value. I wonder what would cause them to be different in the first place. It is the biggest deal for Super WHY! since that is in heavy rotation at our house and my wife has to hunt for the right show. Let me know if I can provide any more detail on this.
there was also a bug a couple versions ago where preserve original metadata didnt actually preserve the original metadata... once this was fixed up i had 2 series for a couple of my shows too... i had to go and correct the ones that bmt messed up... and ever since the bug was fixed and i fixed up hte messed up ones things have been hunky dory...
System Setup: Server 2003 r2 32bit, SageTV7.1.9 2x Dual HDHR (OTA), 1x HD-PVR (Comcast), 1x HDHR-3CC via SageDCT (Comcast) 1x HD300, 1x HD200, 1x HD100 (remote placeshifter), 1x SageClient (Win7 Test/Development) Check out TVExplorer |
Well I just checked and I do NOT have the Preserve Original Metadata box checked? Should I try that. My logic says that would only exacerbate the issue.
-check the "Preserve original metadata" box -manually go through and fix the old videos to match the title in the epg. Only fix the "Show Title", leave the "Fanart Title" alone. Then, going forward, youl'll be all set...
). I would actually prefer the tvdb show titles that BMT fetches to be the show title in Sage. With Super WHY! it is not a huge deal (since the difference is only capitalization), but with shows like The Amazing Race it makes a difference since in the EPG it has a different name every season. The bottom line is that it seems like BMT is doing its job correctly, but for some reason Sage is not picking up on this metadata and is 'reverting' to information from the EPG.
| Tags |
| bmt, show, title |
| Display Modes | |
| Fixing Show Title | jcato | Batch Metadata Tools | 17 | 01-18-2011 05:44 AM |
| API call to convert show title to file name? | Slugger | SageTV Studio | 5 | 06-03-2009 02:42 PM |
| Clarify the title/artist bit eg. [DVD TITLE] / [MOVIE TITLE]? | bcjenkins | SageMC Custom Interface | 1 | 12-31-2008 10:58 AM |
| Can anyone twll me what the numbers after the show title mean in the filename? | zubblwump | SageTV Software | 2 | 02-14-2007 11:25 PM |
