| SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here. |
Use hostname in auto-connect instead of IP?
Is there a way to configure STV Client (7.1.5, FWIW) so that if I tell it to "Auto Connect", it will attempt to auto-connect to a hostname instead of an IP Address? Doesn't appear to be an option from the GUI.
I have almost all my PCs (including "servers") using DHCP because my internal DNS resolves them very consistently. Thus, my STV Server won't change in name, but it may change in IP Address over time, and simply allowing me to enter a hostname (or FQDN - but that's overkill) in the STV Client config should solve the problem. Thanks, AJ
"A CPU is a terrible thing to waste."
Go into your router and assign the MAC of your server the IP address you want it to keep. That way no matter what happens it will always get that address. Auto connect can only use the IP number AFAIK.
The amount of coding necessary to resolve a hostname is so trivial it's not even worth mentioning, but the convenience for end-users is night-and-day over having to enter and maintain an IP Address. I can't be the first person to ask for this.
In the client's server selection box, simply type in the hostname to connect to instead of selecting an address from the drop box.
SageTV v7.1.9 is available here. - Read the SageTV FAQ and PDF User's Guides for SageTV V7.0 & SageTV Studio v7.1. - Hauppauge remote help: 1) Basics/Extending it 2) Replace it 3) Use it w/o needing focus - HD Extenders: A) FAQs B) URC MX-700 remote setup Note: This is a users' forum; see the Rules. For official tech support fill out a Support Request. Before you ask: no, I can't say "when".
Thanks, AJ
While I agree that connecting by host name is preferable, in the long run you're going to want a fixed IP for your server so you can do port forwarding for Placeshifter, remote access to the web server plugin, and so on (unless your router can do port forwarding by host name instead of IP).
-- Greg |
Awesome info. Thank You.
Agreed, for port-forwarding I would need a fixed IP Address (I don't know of any that will resolve the hostname for forwarding, but that would be very cool). I haven't played with the web server plugin much; not to push us onto a tangent, but what would I do with it when connecting remotely?
Same sorts of things you would use it for locally: checking the status of your server and clients, scheduling recordings, managing favorites, browsing the EPG to see what's on tonight, etc.
-- Greg |
| Display Modes | |
| Auto Connect/Reconnect for Placeshifter | bfhoothead | SageTV Placeshifter | 31 | 10-25-2009 10:32 AM |
| HD200 Auto-Connect Time | simonen | SageTV HD Theater - Media Player | 8 | 03-21-2009 08:05 PM |
| Is there any way to auto-connect to a SageTV server? | mkanet | SageTV Placeshifter | 1 | 11-28-2007 03:51 PM |
| Auto-connect to server | flavius | SageTV Placeshifter | 5 | 04-12-2007 12:57 PM |
| Sage Client auto-connect... | Niles | SageTV Software | 2 | 03-30-2004 02:34 PM |
