| SageTV v7 Customizations This forums is for discussing and sharing user-created modifications for the SageTV version 7 application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss plugins for SageTV version 7 and newer. |
Plugin: Automatic Power Off
Hi,
I would like to introduce you "Automatic Power Off" plugin for extenders (MVP/HDx00). This is my first ever SageTV plugin for v7.1. I did it mainly as exercise for another plugin which I'm going to release soon and which shares some libraries so it did make some sense. I know this is not a new thing, and there are plenty of ways outhere to achieve the same result, but I thought this plugin could be useful to some of you considering that: - The extenders are now a rarity, in particular the HD300 which is running hot, so at least keep it off/ready when not in use help to cool it down at least. - If you have kids like mine whom switch on the equipment and kindly "forget" to switch it off when finished. - I you like me have the extenders hooked on power timers that switches them on in the morning and off at night. - Well, I'm sure that if you like it, you'll find plenty of good use. The plugin must be installed on the server only and have a single configuration option the "Inactivity Timeout" in seconds that can be accessed once the plugin in installed and is global for all extenders. Please use this thread to send me you feedback, issues or feature requests. thanks for listening ;-) Eddy
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video |
Does it poweroff and extender if a screensaver (slideshow) is enabled?
Wayne
i7-870, Gigabyte GA-H57M- Micro ATX MB, 4GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 7,Ceton CableCard Tuner, 2 x HDHR, 2 x HD300 + 2 x HD100 |
Yes, the screensaver functionality are completely separate from this plugin, so their respective timeouts, if a screensaver is already enabled and playing when this plugin timeout kick in, the extender will power off regardless.
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video Last edited by routerunner; 01-13-2012 at 04:21 AM. Reason: typo |
HD100 testing please...
I don't have an HD100 myself, so I couldn't perform any testing on that extender. Can someone please test this plugin on HD100 and let me know the result? It should work, however I'll really appreciate whether someone can do this test for me.
many thanks Eddy
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video Last edited by routerunner; 01-13-2012 at 04:47 PM. |
It works as advertised! Screen saver came up and later it shut off (HD-300)
I just reset the timeout to 30 sec and tried it on an HD-100. Nothing. What would be cool is if it could control other components. I have a TV and receiver hooked up to the HD300 that are also controllable via serial port (currently using eventghost). Thanks for the plugin. Wayne
Would it be possible for you to hook your HD100 on the DMZ port of your router for me to investigate further please? If so, please PM me with your public internet address. many thanks Eddy
Are you thinking from the extender via the onboard USB ports? I would personally prefer to use the HDMI-CEC functions...will see
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video Last edited by routerunner; 01-14-2012 at 10:06 AM. Reason: typo |
Could the plugin be adapted to optionally run an external process - ie any batch file or executable? That way one should be able to run another process that shuts off the other components, either via a serial, TCP or even an IR blaster.
Sage7 on Win7Pro-i660CPU with 4.6TB, 2xHD-PVR(connected to SA3250HD+SA4250HD-Rogers Cable), HDHR(2xOTA), HVR-1850(one OTA, one connected to SA3200 SD cable box), 2xHD-300, 8xHD-200 Extenders, Client+2xPlaceshifter and a WHS which acts as a backup Sage server |
BTW, did you see my post regarding having access to one of your HD100? thanks Eddy
Easy mistake - you just got the wrong Wayne!
Twitter: @ddb_db Server: Intel Q6600 Quad Core, 2GB RAM, 1 x 80GB OS HD (WinXP SP3), 2 x 750GB recording drives (RAID 1) NAS: unRAID server 4.7.0; 3TB Capture: 2 x Colossus, 2 x PVR-250 STB Controller: 1 x USB-UIRT Software:Java 1.6.0_33; SageTV 7.1.9 Clients: 1 x HD300, 2 x HD200, 1 x SageClient, 1 x PlaceShifter Plugins: Too many to list now... |
thanks Eddy
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video Last edited by routerunner; 01-15-2012 at 02:49 AM. Reason: typo |
Enjoy...
thanks again for your help Eddy
I'll see if I can get this done for you. I was mostly interested in it for the hd300, but I suppose it would be good for the hd100s, too.
Thanks again for the plugin. Wayne
Many thanks, I'll really appreciate that.
As I was falling asleep last night watching channel 1012 on an HD200, I was pondering if it would be possible to have the HD200 shut itself off after an hour or so. When watching liveTV, I assume there is always continuing activity even after the target live show is over (it just continues to play that channel), so perhaps this particular plugin wouldn't act as a sleep timer, but perhaps there is something that could achieve this? Is this sleep feature already built into the unit somewhere that I haven't yet found?
Is there any way to achieve this so that I can just walk away from any HD200/300 in the house, or fall asleep, knowing that it would just shut itself off after "x" minutes? |
Seriously though, there is not such a thing that reliably knows whether there is someone in front of the telly or not without giving you false positives. You're right if you're watching a live show the plugin will automatically go into idle until you stop any kind of playback, then it will start the countdown to power off the unit, any activity such as even using the remote will reset the countdown to its specified value again to avoid any false positive. What you really want is a sleep timer function, something that must be set for each extender individually and that you must need to setup before watching anything to be sure that the extender will power off automatically. This plugin currently doesn't do that, but I'll add this feature into my wishing list. Thanks for your feedback
| Display Modes | |
| Plugin: Automatic Aspect Ratio Mode Switcher | JREkiwi | SageTV v7 Customizations | 46 | 03-30-2011 11:24 PM |
| Automatic system and power shutdown | mhubel | SageTV Customizations | 0 | 07-29-2010 07:13 PM |
| Automatic aspect plugin for Sagemc | Hunter69 | SageMC Custom Interface | 3 | 11-16-2009 06:53 AM |
| Sky automatic power on | harryf | SageTV United Kingdom | 6 | 02-14-2008 03:24 AM |
| Automatic DivX Encoding and Automatic Commercial Removal? | TurboRX-7 | SageTV Customizations | 3 | 07-28-2005 09:00 PM |
