| SageTV v7 Customizations This forums is for discussing and sharing user-created modifications for the SageTV version 7 application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss plugins for SageTV version 7 and newer. |
| View Poll Results: Are you interested in a "Try before you buy" option? | |||
| Yes, please |
7 | 70.00% |
| No, thanks |
3 | 30.00% |
| Voters: 10. You may not vote on this poll | |||
Hi,
I'm very pleased to announce you the "Squeezeslave" plugin which allows you to add headless squeezebox capabilities to your beloved SageTV extender. Please follow the thread HERE for further information. Eddy
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video Last edited by routerunner; 01-27-2013 at 12:24 PM. Reason: Removed support for old version |
as a plugin does this now work with 100s or is it still 200 and 300 only?
Congrats on the quick evolution from idea to reality to plugin. thanks
Server: PhenomII X4 810, 16GB, 4850, C: WD 750, D: WD 2T-red, E: WD 1TB-green, H: 3T Seagate, 1.5 TB on NAS via UNC, Win 7 x64, Sage 7.1.9 Cable provider is Comcast Tuners: 2 ATSC - Kworld UB435Q connected to attic mounted Channel Master CM2016, great reception, 3 QAM - HDHR Prime, 4 Cable via Ceton and SageDCT, 1 HD-PVR (in tuner priority order) Clients: Wired: HD300, HD200, HD200 running Squeeze Slave, HD100, Placeshifters, HD200 (via wireless N bridge, linksys wrt320N running dd-wrt), |
Supported extenders: HD100????
In the meantime... Is someone in the community willing to help? I need to access remotely one HD100 for development purposes. If you're serious about it with a very good internet connection and don't mind to leave the equipment on 24/7 for few weeks, please PM me with your interest and I will contact you when time will come.
SageTV 7.1.9 - 2 x HD300, 3 x HD200, 1 x HD100, 1 x MVP, 1 x SageTV client _______________________________________________________________________ Automatic Power Off | Squeezeslave | DVB-S Importer DVB Decrypter & Card Client | Easy way to speed up Fanart browsing + Video |
New version available: Linux and Mac support added
I've just released version 1.0.1 which supports both Linux and Mac servers.
To make it working you simply have to follow these instructions: Linux ==== 1) login as root 2) edit "/etc/exports" adding the following line: /opt/sagetv/server/plugins/squeezeslaveplayer *(ro,sync,no_subtree_check) 3) restart the NFS server Mac === 1) login as root 2) edit "/etc/exports" adding the following line: /<SageTV-install-dir>/plugins/squeezeslaveplayer -ro -mapall=nobody 3) restart the NFS server I haven't tried the Mac version as I don't have one, so if anyone could give it a go would be great
HD100 porting status report
The porting of the Squeeze Slave Player to the HD100 is going well...actually better than I thought originally.
I reckon I will be able to complete the 8620 Linux driver in a couple of weeks max. The player has been ported and compiled (GNU 2.95.3) to ARM as well as the generic sound driver and they run as expected on the HD100 already. On a side note, as I haven't received so far any feedback about this plugin, I can assume either everything is working as expected (I doubt it) or nobody is currently using it ![]() I would like to hear your opinion and suggestion please... many thanks Eddy
How can I get sound to play out hdmi I'm using an hd300?
Update: The answer was in the other thread. Just have to start playback of an audio file and piause it. Then u can play from squeezeserver. This is awesome. Will it be possible to not have to do this whole pause thing in the future? This is really big achievement for the sage community! Last edited by Gustovier; 01-30-2012 at 11:55 PM. |
thanks Eddy
I'm using this plugin successfully on a HD200 with my squeezebox server. It's great for tunes in the garage.... and I use iPeng for my ipod touch to control it via wifi. Works pretty slick. And no need to power up the monitor / projector out in the shop just for tunes. Nice work.
I've only used ita little. I use the squeezebox ap on my tablet.
I have one small problem I am trying to document...ot sure exactly the sequence required. If I listen to music some via squeeze client, then switch to sage, I get chipmunks for music and recorded files. Switching back to the squeeze client and the frequency shift persists. have to do hard reset to get back to normal. this is on the HD200. have not tried on my HD300. |
OK, so how do I STOP music squeeze playback?
Someone in the forum said (I think it was stanger89) that this is the closest you can get to a Logitech Squeezebox Receiver, so the music playback/pause/stop can be controlled by the squeeze server web interface or by any other client that support the squeeze protocol like the Boom or the Radio.
HD100 European beta tester wanted please...
I'm looking for volunteers to start testing the HD100 version of this plugin.
Unfortunately the test cannot be performed stand alone so I need to have remote access to your HD100 and simultaneously a Skype call as you need to be my ears .The reason why I need to have some volunteer from Europe is to minimize the time difference as the testing will be only performed on evenings and don't want to interfere with your sleep too. If you are seriously willing to help please PM me with your interest many thanks Eddy
Seems the next thing that really needs to be tackled is more on the sage side of things. This really requires a way to handle basic control from within the sage UI. Meaning, automatically stopping the music playback when media playback begins, and vice-versa. My initial thoughts on this are to handle send commands from the sage UI to the squeeze server... just not positive on the method best to use. I'm aware of the CLI (which is basically a telnet interface) and I think there is some sort of http based protocol as well - which, if functional for this feature, would probably be easier to integrate into the sageUI.
Handling some of this basic functionality at the UI level would potentially be able to work with traditional clients as well, as long as the player ID was set up in sage.
Sage Server: Phenom II X4, 16GB RAM, Win7HP, 1x1TB (system/misc-imports), 2x750GB+3x2TB(recordings/media) Sources: Two R-5000HD equipped ViP-211's for Dish Network, HDHR3 Dual for OTA Primary Client: i3-530, 2GB RAM, Win7HPx86, miniITX H55 MB, 160GB laptop drive, Samsung HLT-6189S Other Clients: Phenom II X2 545 w/8GB and HD6670 in Master Bedroom, MVP in kids play room |
I've got already an idea on how circumvent this, however for the time being I'm concentratating the efforts on making this plugin running on the HD100 as well as the MVP (yes, you heard correctly I'm on it in parallel and making good progress too ) and the main reason is to gather all the hardware specific differences/limitations/pitfalls in order to have a complete picture and provide an effective working solution.There is still more to come... Talking about HD100, I haven't got a reply from a EU volunteer beta tester yet...I think that there aren't many HD100 in Europe as in USA though, will see...
In my use case, I would prefer all control to be handled by the sage side of the house. SqueezeSlave should always be running on all applicable clients, but be 'powered off' via the Squeeze Server when not in use. Then, you can, via a sage menu, turn the SqueezeSlave on (which will simply send a GET to the HTTP ui). It would then stay 'ON' until powered off via the squeeze server, or the Sage UI (upon playing media). I was already wanting to implement this on my client, so I'll see what it takes to do. It should en up being a relatively simple UI Mod, with the only property involved being the Squeeze Client ID associated with that sage client.
Tom
Sage Server: ASUS/Intel C2D based system w/4GB RAM. WinXP Home, Hauppauge PVR 150, Hauppauge HVR-2250 and an HDHR. Runs headless. Accessed via VNC when necessary. Four HD-300 Extenders. |
many thanks Eddy
| Tags |
| ipeng, remote, squeeze center, squeezebox, squeezeslave |
| Display Modes | |
| Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) | cslatt | SageTV Customizations | 48 | 06-11-2012 10:44 AM |
| Plugin request for SageTV Windows Client: Autofrequency plugin | mkanet | SageTV v7 Customizations | 3 | 11-12-2011 08:33 AM |
| SageTV Plugin Developers: Any way to see stats for your plugin? | mkanet | SageTV Software | 4 | 12-12-2010 09:33 PM |
| MediaPlayer Plugin/STV Import: Winamp Media Player Plugin | deria | SageTV Customizations | 447 | 12-11-2010 06:38 PM |
| Plugin Manager: Configure plugin | medwynd | SageTV Beta Test Software | 0 | 05-29-2010 08:43 AM |
