Breakout cable vs HDMI
Hi,
I've just hooked up my HD300 to my new Samsung smart TV and am having problems. With the Audio when using HDMI cable.the problem is crackling audio and some white specs on screen. I have tried All combinations of audio output on the stb but just can't seem to fix it. I have had success with using the sage breakout cable though. With respect to what sage can offer what is the difference between the breakout cable and the hdmi.? Should I be happy that I can only use the breakout? Cheers. |
A shorter HDMI cable may help. The HD300 is known for having a rather weak HDMI output signal.
Server (Headless): MSI H57M-ED65 mATX Motherboard, Intel i3-530 CPU, 4 x 2TB Hitachi Drives, Win7 Home Premium 32 bit, SageTV 7.1.9 Tuners: 4 x Hauppauge WinTV-HVR-2250 Dual TV Tuner Boards, 1 x SiliconDust HDHomeRun Dual Digital TV Tuner (OTA) Clients: 4 x HD300 Extenders, 2 x HD200 Extenders Miscellaneous: 2 x Sony RM-VLZ620 Universal Remote Controls |
That sounds like a plausible solution, thanks for the tip.
Off hand do you know the length of the included Sage HDMI cable? I'm not at home to measure. I'll order a shorter one on ebay now. Thanks. |
I'm not home either. I would guess 2 meter???
| Display Modes | |
| Wanted: HD300 Breakout Cable | mrcandu | SageTV Marketplace | 4 | 05-25-2012 11:46 AM |
| SCART RGB through breakout cable on the new 300? | radiopaque | SageTV Media Extender | 2 | 09-01-2010 12:36 PM |
| HD100, HDMi to DVI cable at 720p | Gog | SageTV Media Extender | 1 | 03-13-2008 10:55 AM |
| Using a DVI-HDMI cable | jgs14 | Hardware Support | 7 | 03-10-2008 05:22 PM |
| Breakout Cable to HDTV Help | DKT | Hardware Support | 0 | 10-15-2004 08:01 AM |
