Detailed Setup / Advanced / 3D Acceleration = Enabled/Disabled
Abit AN-AM2HD | AMD5000+ | 2048MB DDR2-800 | ATI-3650 | 3TB Storage | Sage 6.4.8/Meedio 1.41 | XP 32BIT | FireDTV S2 | WinTV-NOVA-S+ | USB-UIRT/MX-500 Remote | Antec Fusion Case | Zalman Reserator 1 V2 | 1GB NIC`s |
Perhaps test sage on a completely dedicated PC if you have available
Not much experiece with running SageTV on MCE but maybe this is an issue within itself... not sure. All I can say I have built many a SageTV setups and although I have seen that error message beforem, the suggestions that others have made would always clear things up or help point me to the root of the problem in no time at all. If you don't have another machine perhaps you have another hard drive to play around with Sage without jeopardizing your MCE setup (or vice versa). Quote:
Server: Dual Tuner: PVR-150MCE/PVR-250MCE/SageTV v5.02/Asus Pundit-R 2.4GHZ/512MB DDR RAM/250 GB Maxtor HD (8MB Buffer) External Seagate 400GB HD via USB 2.0/Onboard ATI 9100 using SVIDEO TV-Out/Nvidia DVD decoder/Actisys 200L IR Blaster (Dish receiver) USBUIRT (DirectTV receiver)/Lite-On 4X DVD-R/RW/Windows XP Pro SP2/Adesso Mini IR Keyboard w/integrated mouse/Tivo "Peanut" Remote via USBUIRT/Dish Network Model 301/DirectTV subscriber/Webserver Plugin v2.8 |
According to SageTV it is compliant on an MCE box with the obvious services disabled.
Can someone tell me what effect turning 3D off has? Many thanks to all for their replies. There is a prize to the person that gets me up and running. Darren |
I thought everything was going well until while watching live tv I tried going to guide...nothing...then main menu...nothing....live tv was still playing!
I VNC'd into the box and my PC monitor was in fact showing me the main menu and the TV live tv....very odd and VERY annoying. What's up? Darren |
Guys,
Putting this PC into single display mode (it was in clone mode as I have an Infocus projector connected to the video card (FX5750) DVI output) seems to work. However, although I don't need to see live tv on the TV and projector at the same time I don't want to have to manually keep switching to clone mode or assigning the projector to be the primary display, etc. each time I want to watch something on the projector. Is there a solution? Cheers Darren |
Sounds like you are using overlay renderer in Sage (which will always be the case if 3d accelleration is disabled), and your nvidia display settings are confgured to have full-screen overlay on your TV-out, which means that whenever any video is played, it will be full-screen on the TV...
With most video cards video playback works best on the primary monitor (often VMR9 stutters on secondary, and usually overlay does not work at all on secondary). So, if you want Sage on your TV-out, set the TV to be the primary monitor. To disable full-screen video, go into display control panel/settings/advanced/FX5750 tab/Fullscreen video, and set Fullscreen Device to Disable... Restart Sage on the TV-out, and you should now get menus at the same time as video... Why did this not happen in MCE? MCE uses VMR9 renderer (I believe) in Full Screen Exclusive mode -- You can configure this in Sage, (3d accelleration enabled, video renderer VMR9, full screen excusive mode), but given the problems you have been having, I think it will create more problems
Check out my enhancements for Sage in the Sage Customisations and Sageplugins Wiki |
So, as you have learned, MCE works on its own setup configuration within Sage. It is running VMR9 for renderer and in Full screen mode. You do not set these settings, they are default when using the MCE.
And you have been instructed to make sure you are using the older version of Java. The STV for sage (on a computer, not the MCE) you configure for the computer. If you choose VMR9 for the render you will need 3D acceleration enabled. However, the VMR9 and 3D has given you and many users problems... old threads in this forum seem to show the PVR350 has particular problems with this. Overlay with 3D disabled is about the most basic, and should work with most any system. However, there are always a few individuals who will have problems with any settings, for no apparent reason. You have already tried using just the 150 and leaving the 350 out of the loop for now which is best until you have stability. It can be a pain trying all of the possible combinations of renderers and Mpeg2 decoders, and, in your case, primary monitors. So, pick a monitor, pick a decoder, and start changing renders. Etc. Have fun; and when you just can't stand it any more, simply post back to the forum and someone else will offer a suggestion which will inspire you to try again. What was that definition of insanity... trying the same thing over and over and expecting a different outcome? Last edited by wrwaugh; 06-10-2006 at 07:46 PM. |
I had similar issues when I used a dual monitor setup with the Infocus PJ. I eventually made the Infocus the primary display and it worked fine, but I still got jitters.
In the end I dedicated the computer for HT use only and got rid of the monitor, it made a tremendous difference in how fast it worked, and from then on I had no problems to speak of. Well, I should say once I pulled the 350 out I had no problems, you'll never have a completely stable system with that card in there IMO. For what it's worth I used the Nvidia drivers and 3d with VMR9 of course and turned off the output from the 350 using only dvi. Worked fine. |
PlaybackException fix (for me)
While experimenting with some settings, I turned "Full Screen Exclusive" on, and everything worked fine. I then forgot about the change. Two days later, I started getting intermittent PlaybackExceptions (0x80040217). Finally, I remembered, and turned that setting off. At first, it still didn't work. But I changed my decoder from Nvidia to SageTV, and it worked. I then changed the decoder back to Nvidia and it still works. Sheesh, that bugged me for quite a while. Hope that saves someone some time!
And just FYI, "STV" usually referred to the skin or theme for SageTV.
Mayamaniac - SageTV 7.1.9 Server. Win7 32bit in VMWare Fusion. HDHR (FiOS Coax). HDHR Prime 3 Tuners (FiOS Cable Card). Gemstone theme. - SageTV HD300 - HDMI 1080p Samsung 75" LED. |
I feel a bit guilty as I answered your original post with a 'yes this will work' recommendation.
However: Quote:
I agree though that as MCE uses VMR9 FSE then that would be the best solution to get working in Sage (in my view the deinterlacing is better using VMR9). Unfortunately mine is now working flawlessly so I can't offer any advice other than to back up neilm's recommendation. I also use ultraVNC and its video hook driver can sometimes cause problems. Some recent nvidia drivers have caused wierd problems for me (random frames being interspersed into the video, surreal effect). But the latest drivers seem to work well. I don't know if the xmltv importer that you are using requires Java 1.5.x (I use the lmgestion importer which does). If not then downgrading Java to 1.4.11 helps prevent some problems (though not specifically as you describe). I have found Java 1.5.5 and 1.5.4 unstable but so far Java 1.5.2 seems OK and still allows the lmgestion importer to run. Hope this helps Eric |
