Old 05-06-2010, 09:14 AM
valnar valnar is offline
Best PCIe analog tuner?
I know a pure analog tuner probably doesn't exist for PCIe, so I'll settle for something that has both analog + digital. I am replacing a wonderful Hauppauge PVR-250 board because a new Sage Server I'm building will only have one PCI slot. That single PCI slot will be for one of my two PVR-250 boards. The other gets retired.
Ideally, something that is very reliable, works in Windows 2003 (PVR-250's did with XP drivers) and CC support if possible. Video quality is least important compared to stability and compatibility.
Recommendations?
Client 2: HD300 on Vizio 40"
Old 05-06-2010, 09:47 AM
mgkicer mgkicer is offline
Hello valnar,
My recommendation is to get an HVR-2250. I have two of them, one almost 2 years this summer (very reliable). I am sure it would work with Windows 2003 as I have mine working perfectly with XP. I have not updated my system for fear of breaking it (still running old drivers with beta 6.5.11 on a gigabyte ATX 780g/4850e combo). I do OTA only and in two years I've only missed a couple of shows due to first run flag (changed it to record all) and signal issues (fox got weird for a week last year and then it went away). The HVR-2250 is a little pricey, but I can attest to the reliability and the gorgeous OTA HD quality (the card does analog on both tuners as well, but I have never tried it). Also, I have never tried CC on this card, sorry.
Max
ATI HD 650 PCIe QAM and analog simutanous problems SnakeJG Hardware Support 1 03-25-2010 08:42 AM
Avertv Combo PCIe M780 Tuner Card Supported? ARMYB77 Hardware Support 28 01-27-2009 10:36 AM
Long time analog Sage user seeks new analog/digital tuner advice robmarch Hardware Support 11 12-11-2008 01:15 PM
TV Wonder HD 650 PCIe or WinTV HVR-1800 PCIe? phenixdragon Hardware Support 0 12-10-2007 06:42 PM
What's the highest quality dual tuner PCIe card? mkanet Hardware Support 11 05-31-2007 03:33 PM
