Old 03-27-2014, 04:52 PM
Doubledose's Avatar
Doubledose Doubledose is offline
Plugin failed
I have not been around much on here, But I have had some notifications to do updates. But I get failures when I try to do updates some times. Can anyone look at these snipit files and tell me what might be wrong?
Wayne
Asus Commando MB | Intel Core Quad Q9400 CPU | 500 GB WD system drive | (2) 1TB Seagate drives pooled | 2 GB DDR ram | Viper HD4650 video card | Win 7 64 bit | SageTV 9 | (5) Sage HD TV extenders | (1) HDHomeRun Connect for HD OTA | (1) Older HDHomeRun set for HD OTA | (2) HD-PVR'S recording from 2 Dish Network VIP 211K's with Uirt ir control | MX-700 Home theater remote | 60" LED TV | (4) 32" Lcd TV's
Old 03-28-2014, 02:31 AM
Slugger Slugger is offline
Those errors mean you're not running SageTV v7.1.9, which is what the plugin requires. Upgrade to the latest version of SageTV to fill that dependency.
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 03-28-2014, 04:39 AM
Doubledose's Avatar
I did find the download and have it downloaded. Do I also need to download this update that I came across while looking for the update?:
The latest v7.1 STV update: STV v7.1.9.12, 2013010701
All v7.1 STV updates:
STV v7.1.9.11, 2012101601
STV v7.1.9.10, 2012100501
STV v7.1.9.9, 2012100301
Wayne
Old 03-28-2014, 07:14 PM
You need to upgrade the server software, not just the STV (i.e. UI). You need to download the 7.1.9 installer and upgrade (if you're able to find it anywhere). This might also require a different license (or the patched binaries to allow use of older licenses). All those details are available in other threads throughout this forum.
Twitter: @ddb_db
Old 03-30-2014, 10:56 AM
Doubledose's Avatar
Thanks slugger
Got everything updated I think!
Wayne
Plugin request for SageTV Windows Client: Autofrequency plugin mkanet SageTV v7 Customizations 3 11-12-2011 09:33 AM
Automatic Metadata Failed (Code 10100) IMDB: Failed to parse providerDataUrl: mkanet Batch Metadata Tools 2 10-12-2010 03:22 PM
ComskipPlayback plugin install failed hogburgs SageTV v7 Customizations 3 08-29-2010 07:51 PM
