Old 09-01-2020, 12:35 PM
xjim1's Avatar
xjim1 xjim1 is offline
No ac3filter?
On my old XP box(9.1) I've used the ac3filter. But on my Win10 install it's nowhere to be found. On Sourceforge it looks like it's only a 32bit program, but can't I still use it on a 64bit 9.2 Sage install?
Old 09-02-2020, 10:37 PM
xjim1's Avatar
Nothin'? Nobody's tried this?
Old 09-03-2020, 08:17 AM
Maybe it isn't needed any more as Win7, 8 and 10 came with more codecs built in.
Old 09-03-2020, 09:33 AM
MattHelm MattHelm is offline
This link says it supports 64bit. https://www.start64.com/index.php/64...3489-ac3filter
Old 09-03-2020, 05:45 PM
wnjj wnjj is offline
Here’s why it isn’t included for 64-bit: https://forums.sagetv.com/forums/sho...&postcount=209
Windows Installer
Old 09-03-2020, 08:53 PM
xjim1's Avatar
Thanks Matt for the link. The more I looked into it the more I smelled something fishy. Never used the codecs website before...
...glad I asked. Thanks wnjj for finishing my homework for me. I must have only searched the software forum. How are you at math?
No DTS Passthrough with AC3Filter TwistedMelon SageTV Software 23 07-21-2013 07:40 PM
Why do I want AC3Filter? rwc SageTV Beta Test Software 4 10-19-2005 09:11 AM
Specifying AC3Filter Blue SageTV Software 4 03-04-2005 10:40 PM
AC3Filter 1.01a soulprops77 SageTV Software 7 01-27-2005 03:48 PM
AC3Filter Question m0ng00se30 SageTV Software 2 11-13-2004 10:03 PM
