Old 09-28-2011, 12:11 PM
dooferlad's Avatar
dooferlad dooferlad is offline
Post digital switchover PredefinedDVBT.frq
In order to get Sage to scan channels in the Oxford area post switchover today I had to modify PredefinedDVBT.frq so the Oxford transmitter listings has the frequencies from here:
http://www.ukfree.tv/txdetail.php?a=SP567105
I am happy to share the updated file, but it seems to me that a wiki page for it may be more useful so we can work together and keep it up to date. Is a page on http://sagetv.wikispaces.com/ the right place to start?
Old 11-12-2011, 09:32 AM
ElGato's Avatar
ElGato ElGato is offline
Send a message via ICQ to ElGato Send a message via MSN to ElGato
please share
Old 11-13-2011, 12:18 AM
dooferlad's Avatar
Ah, you find me away from my machine for several weeks. If you are still in need in December, please ping me and I will upload what I have.
Old 11-23-2011, 07:19 AM
jaminben jaminben is offline
We had our DSO today in the east.... if anyone else in this part of the world needs the new .frq frequencies I've put what I used below.
"United Kingdom-East Anglia@Tacolneston"
frq:745800000;band:8;
frq:778000000;band:8;
frq:801800000;band:8;
frq:642000000;band:8;
frq:666000000;band:8;
frq:706000000;band:8;
{tune:1;pat:6;sdt:16;}
Thanks to the OP for the tip as I was a little confused as to why no channels would tune
Old 11-23-2011, 08:15 AM
jamesdisco's Avatar
jamesdisco jamesdisco is offline
Would you be able to post here where you are getting these new settings. The North-East doesn't change until next year but I'd like to know where to get the frequencies when the time comes.
Server: Win 10 64bit Core i3 8GB 20TB, TBS6985, TBS6984, Sage 9.
Clients: 5 x HD300, 2 x HD200, Placeshifter.
Old 11-23-2011, 05:36 PM
starfire starfire is offline
You could go here for example http://www.ukfree.tv/shutdowndetail.php?tx=SE553962
Then scroll down and see the channels after the 2012 switchover, click each channel and it will show you the frequency
eg. UK TV Frequency map - channel C23 (490.0MHz) after switchover
Old 11-23-2011, 05:46 PM
Pretty much as starfire said.... just look for your transmitter and enter the new frequency. Takes about 2 mins to do as theirs only 6 to change.
Old 01-06-2012, 10:23 AM
Hi Michael,
I attached my frq here as I couldn't see where to attach it in a PM.
Ben
Old 01-17-2012, 01:04 PM
emotionnotion emotionnotion is offline
I am currently tuned to Belmont which is shown as:
"United Kingdom-North@North@Belmont"
frq:546000000;band:8; (Mux 1
frq:690000000;band:8; (Mux 2
frq:850000000;band:8; (Mux A
frq:834000000;band:8; (Mux B
frq:786000000;band:8; (Mux C
frq:762000000;band:8; (Mux D
These settings change in late August; I have had intermittent tuning issues since then with SageTV;
I have listed which the Mux settings against the http://www.ukfree.tv site.
Before/After switchover the site suggests:
Multiplex names Public services Commercial mode
Before switchover Mux 1• Mux 2 Mux B• | Mux A Mux C• Mux D• | •16QAM, 64QAM
After switchover BBCA D3+4 BBCB•• | SDN ArqA ArqB | 64QAM, ••256QAM
Does that mean I should change it to:
frq:546000000;band:8; (Set to BBCA
frq:690000000;band:8; (Set to D3+4
frq:850000000;band:8; (Set to SDN
frq:834000000;band:8; (Set to BBCB
frq:786000000;band:8; (Set to ArqA
frq:762000000;band:8; (Set to ArqB
Is that right?
Server: Tranquil T7 Intel Atom D330, 2GB RAM, Windows Home Server, Sage TV 7.1.9 (Last version ever ), 2 HDHomeruns tuning 4 OTA channels, Sony 32EX490 Bravia LCD
Clients: 3 HD300s, 2 HD200s, 1 PS3
Old 01-17-2012, 01:24 PM
doc doc is offline
Think you may have made a type on your cutting and pasting.
I'd try it with this, I think. It's not my transmitter but I used the same method that I used for my own which worked ok.
frq:474000000;band:8; (Set to local
frq:482000000;band:8; (Set to BBCA
frq:506000000;band:8; (Set to D3+4
frq:530000000;band:8; (Set to BBCB
frq:546000000;band:8; (Set to SDN
frq:570000000;band:8; (Set to com7
frq:586000000;band:8; (Set to com8
frq:594000000;band:8; (Set to com9
frq:730000000;band:8; (Set to ArqA
frq:786000000;band:8; (Set to ArqB
Old 01-17-2012, 01:28 PM
You have copied all channels I think; I ignored the COMS for example as they were not in my original FRQ.
Makes sense to copy them all so thanks
I thought they needed to be in a specific order so I only mapped the six channels before switchover to their post-switchover channels in the same order
Old 01-17-2012, 01:30 PM
Also, this was a version where I only changed the labels not the frequencies.
My frequencies look like yours.
Old 01-17-2012, 01:37 PM
doc doc is offline
The labels are just for comments, I never put any in my own.
As long as the frequencies match, then you should be ok.
I'm not sure about HD channels though, I don't think Sage will pick any of those up, I think you have to manually put the entries into the frq files, but I don't have a dvb-t2 tuner to test it with.
Old 10-11-2012, 03:04 AM
Does anybody have the latest PredefinedDVBT.frq for SANDY HEATH.
All my channels have lowered in signal strength and SageTV tuning no longer finds them.
Old 10-11-2012, 03:35 AM
doc doc is offline
I've had a look here and I don't think it's changed.
Without testing I can't be certain but I'd guess its as below.
"United Kingdom-East Anglia@Sandy Heath"
frq:498000000;band:8;
frq:552000000;band:8;
frq:714000000;band:8;
frq:722000000;band:8;
If you can still tune the channels I'd suspect its possibly an aerial or cable/plug issue. Are you going through an amplifier that might be playing up?
frequency, switchover
Digital switchover in the UK brewston SageTV United Kingdom 4 07-21-2011 02:47 AM
Sandy Heath BBC2 Digital Switchover - What next? emotionnotion SageTV United Kingdom 10 04-02-2011 02:21 PM
HD Switchover ChrisHill SageTV United Kingdom 5 03-01-2011 07:29 AM
March 2011 switchover emotionnotion SageTV United Kingdom 7 02-13-2011 08:45 AM
Channel Scan failing to find channels after Digital Switchover (only in SageTV) fatboy Hardware Support 0 09-10-2009 05:04 AM
