Nielm Webserver streaming issue
I nearly have my SageTV server doing everthing I want. I believe my last problem is getting the webserver to stream video. I can view my pictures through the websever, and listen to my music. When I try to stream video I get this error.
[Mon Jul 02 15:10:44 EDT 2007] /sagepublic/MediaFileTranscode: Exception while processing servlet java.io.IOException: Unable to allocate port for streaming between specified ports 8000-8100 |
Where did you open port 8001?
The port should be opened on the machine where the webserver plugin is running. An alternative may be to add SageTV.exe and SageTVClient.exe as exceptions on the Windows firewall. If these are already open, then I'm not sure what else it may be. |
Issue with Remapping Lastest Comcast QAM Channel Changes | ported | SageTV Software | 2 | 05-19-2007 01:53 AM |
Deinterlace/stutter issue on CBS HD | fist34 | General Discussion | 4 | 05-12-2007 05:48 PM |
Nielm's webserver & squid on same PC | zebra14 | SageTV Customizations | 3 | 11-07-2006 08:30 PM |
WebServer v2.4 WebRemote Issue | mm_junk1 | SageTV Customizations | 1 | 01-25-2006 06:22 PM |
Nielm Webserver Parental Controls | techtips | SageTV Customizations | 1 | 01-20-2006 07:05 AM |
