Old 09-17-2014, 06:04 AM
lovingHDTV's Avatar
Eventghost, Plex and SageTV
I'm hoping that someone has been successful in using eventghost to switch between SageTV and Plex.
My attempts today are:
sageTV to Plex
find plex window
bring to front
switch controls from sagetv to plex
And the opposite for plex to sagetv
The issue I'm having is that after the time out period sagetv starts playing a slide show as the screen saver and this bleeds over onto plex because the task bar pops up.
So I turned off the screen saver, but I still get the task bar popping up and messing things up.
So I tried to minimize to tray each app and that worked, but I when I try to return it later, find window cannot find the minimized app.
I'm hoping someone on here has figured out how to do this and can help.
thanks
david
Old 09-17-2014, 11:02 AM
doodeedoo doodeedoo is offline
I cannot speak to the plex side, as I do not use it.
It's been a little while since I looked at eventghost, but I believe you can load the SageTV plugin and send direct commands to Sage to 1. Wake up (Power On) and 2. Maximize window. At the very least, this will allow you to find the window again with eventghost and bring to front, etc.
Old 09-17-2014, 11:22 AM
When i was using SageTV I used a batch-job the would start SageTV enable SAGETV in eventghost. I then would just exit SageTV and Plex would start up and Sage was disabled in eventghost and Plex was enable... and so on when I exited Plex Sage would start-up etc...
:loop
cd "C:\Program Files (x86)\EventGhost"
c:
EventGhost.exe -e enablesagetv
EventGhost.exe -e disableplex
cd "C:\Program Files (x86)\SageTV\SageTV"
C:
start /w /normal SageTVClient.exe -startup
c:
EventGhost.exe -e enableplex
EventGhost.exe -e disablesagetv
cd "C:\Program Files (x86)\Plex Home Theater"
c:
"C:\Program Files (x86)\Plex Home Theater\Plex Home Theater.exe"
goto loop
exit
Old 09-17-2014, 11:47 AM
lovingHDTV's Avatar
:loop
c:
C:
c:
c:
goto loop
exit
OK I understand the concept here, but where did this run? Windows from the startup directory?
thanks,
david
Old 09-17-2014, 11:53 AM
thanks,
david
There is a lot of ways to start it. You can create the bat file from the code. You can run it at eventghost startup. You can start it up from a remote button that you train in eventghost to launch the application ... etc
Old 09-17-2014, 12:28 PM
texneus texneus is offline
I did something like this to switch between Sage & PowerDVD. To get back to SageTV I run an autohotkey script that searches out and kills all open windows then issues a SageTV command line to open it back up from its sleep state. It might be possible to do it all in eventghost, but it wasn't obvious to me. I'll try to remember to post code when I get home tonight.
Old 09-17-2014, 12:39 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
What you want is for EventGhost to trigger the SageTV: PowerOn command, which will bring it out of the system tray. I do this all the time to switch back and forth between apps. Then, continue with whatever other things you want EG to do.
Software: SageTV 7
Old 09-17-2014, 07:51 PM
You can run this script with Autohotkey (http://ahkscript.org/). It will close all open windows and programs except SageTV and things running in the tray. It then checks if the SageTV GUI is running (possibly sleeping). If it is it wakes it up. If it isn't, it starts it and makes sure it's full screen. I run this script to get back to SageTV with Eventghost when PowerDVD exits or on a Green Button press of the remote (or any other event you might define). I do it this way as I don't think there is a way for Eventghost to do it on it's own...
Change the first variable to point to your SageTV.exe. The other variables should work as is unless there is something funky about your install. You should be able to do something similar to sleep SageTV and start Plex.
;Variables
SageTVPath := "C:\Program Files (x86)\SageTV\SageTV\SageTV.exe"	;Path to SageTV.exe
SageTVPrgWin := "SageTV"		;Title of SageTV Window
SageTVPrgProc := "SageTV.exe"		;Process Title of SageTV
;Closes all open windows except those in the tray, Program Manager, SageTV
;http://www.autohotkey.com/board/topic/69677-close-all-windows-openminimized-browsers-but-not-pwr-off/
WinGet, id, list,,, Program Manager
Loop, %id%
	this_id := id%A_Index%
    	WinGetClass, this_class, ahk_id %this_id%
	WinGetTitle, this_title, ahk_id %this_id%
	If(this_class != "Shell_traywnd") && (this_class != "Button")	;If class is not Shell_traywnd and not Button
		{							;and is not SageTV
		If (this_title != "SageTV")
			WinClose, ahk_id %this_id%			;Then close it...
;Checks if SageTV is sleeping in the system tray and wakes it up if it is or
;starts it if it is not yet running.
Process, Exist, %SageTVPrgProc%		;Check if SageTV Process is already running
If %ErrorLevel% <> 0
	RunWait, %SageTVPath% -event 43	;Power On SageTV GUI in normal mode if it is...
Else
	Run, %SageTVPath%		;...and if it isn't, then start it
	WinWait, %sageTVPrgWin%		;Wait for the SageTV Window to appear
	Sleep 1500			;Short delay for SageTV to initialize
RunWait, %SageTVPath% -event 97		;Maximize window to full screen
Old 09-17-2014, 08:36 PM
Skirge01's Avatar
That's pretty impressive, but a bit more than I'd want. (Not criticizing at all, just a personal observation.) I did mine a little differently, using EG for everything it could do and taskkill.exe for the one thing EG couldn't (kill a process). I included the exact parameters for taskkill, in case anyone is interested.
I kept expanding EG as different scenarios popped up and couldn't be handled via the remote. It's pretty bullet proof at this point and can recover from every situation I've run across so far. I have EG set up so my Harmony remote can control SageTV, XBMC, Total Media Theater, Windows Media Player, MPC-HC, or VLC. The only thing I haven't done yet is set up the remote to launch each of those programs via button presses; that's primarily because I always need to select the file I want to play back first and that's much easier via the keyboard, anyhow. I think I've posted the entire EG file elsewhere on these forums, but if anyone wants to play around with it, I'll post it again.
Software: SageTV 7
Old 09-18-2014, 05:15 AM
lovingHDTV's Avatar
If you would do that it would be great. I tried to search for it, but my searching-skills appear to be lacking.
thank you,
david
Old 09-18-2014, 05:41 AM
ranger ranger is offline
I'll have to take another look at my event ghost configuration for the exact details, but I assigned 4 buttons on my remote to start various applications. The PC is primarily for SageTV, so it is running all the time. The sequence to start TotalMedia (XBMC, etc) minimizes the current foreground window and starts the new application. The context for each application has a shutdown sequence defined that closes the application, restores SageTV annd brings it to the foreground. I don't use this functions often, but they work reliably enough.
If this is what you're looking for, let me know and I'll get the details.
Old 09-18-2014, 09:49 AM
Skirge01's Avatar
thank you,
david
Here you go. (Obviously, remove the .txt) Do keep in mind that if you intend to use this actual file, rather than using it as a guide, you'll need to customize the remote commands to work with your own setup. The file itself should be pretty self-explanatory, but if you don't see why I did something, just ask.
Software: SageTV 7
Old 09-18-2014, 09:52 AM
Skirge01's Avatar
That's pretty much what I did, except I modified SageTV to launch TMT when I choose "play DVD", rather than assigning a button on the remote; when I exit TMT, SageTV is brought back to focus. I rip everything to MKVs, so I don't have a need to use that very often.
Software: SageTV 7
Old 09-18-2014, 10:07 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
When I click on this Link, I get a file called "attachment.php." What program is used to open such a file?
Old 09-18-2014, 10:59 AM
Skirge01's Avatar
That's what you get for using IE. Just do a SAVE AS and rename it.
Software: SageTV 7
Old 09-18-2014, 04:33 PM
lovingHDTV's Avatar
After a little tweaking to convert XBMC windows to Plex Home Theater things are working quite nicely.
The only thing left to figure out is why the "If unsuccessful jump to "Restart XBMC" doesn't work. It just hangs there. If I start Plex on boot then it works fine.
thanks!
david
EDIT: Figured it out, had to uncheck stop macro option. Everything working beautifully now.
Old 09-18-2014, 09:04 PM
Skirge01's Avatar
thanks!
david
Awesome!
Software: SageTV 7
Plex Scanner and BMT Agent for SageTV PiX64 SageTV v7 Customizations 1412 11-11-2022 12:35 AM
Eventghost and SageTV receiving IR lewispm Hardware Support 5 03-04-2014 03:42 PM
Roku+Plex = Leaving SageTV? Anyone regret it? IVB The SageTV Community 60 08-29-2013 07:57 PM
Possible to get SageTV to handle my library more like Plex? DAMAC SageTV Mac Edition 0 06-10-2009 10:33 AM
Can't Get Eventghost to Control SageTV cncb SageTV Software 8 10-12-2008 09:10 PM
