Old 01-28-2017, 07:50 AM
tmiranda's Avatar
tmiranda tmiranda is offline
SSL HowTo?
I'm trying to add SSL support to my Echo skill with little success. The basic problem is that I don't know much about SSL
Here is the relevant code snippit:
        try {
            numberSent++;
            URL url = new URL(protocol, host, port, line);
            Log.log.info("sendMsg: Sending <"+url+">");
            HttpURLConnection httpConnection = null;
            HttpsURLConnection httpsConnection = null;
            // Open the connection.
            if (isSsl) {
            	HostnameVerifier hostnameVerifier = new HostnameVerifier() {
            		@Override
            		public boolean verify(String hostname, SSLSession session) {
            			return true;
                httpsConnection = (HttpsURLConnection)url.openConnection();
                httpsConnection.setDoOutput(true);
                httpsConnection.setRequestMethod("GET");
                httpsConnection.setHostnameVerifier(hostnameVerifier);
                HttpsURLConnection.setDefaultHostnameVerifier(hostnameVerifier);
                httpsConnection.setRequestProperty("Content-Type", "application/json");
            } else {
                httpConnection = (HttpURLConnection)url.openConnection();
                httpConnection.setDoOutput(true);
                httpConnection.setRequestMethod("GET");
            // Set the password.
            if (user != null && password != null) {
                String encodedBytes = DatatypeConverter.printBase64Binary((user + ":" + password).getBytes(StandardCharsets.UTF_8));
                if (isSsl)
                	httpsConnection.setRequestProperty("Authorization", "Basic " + encodedBytes);
                else
                	httpConnection.setRequestProperty("Authorization", "Basic " + encodedBytes);
One of the Echo users has graciously let me run tests on his SSL connection and I am getting this error:
Exception: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Old 01-28-2017, 09:08 AM
EnterNoEscape's Avatar
I think it may have to do with the certificate being self-signed (not issued by a trusted certificate authority). This information is old, but should be relevant.
SageTV v9 Server: ASRock Z97 Extreme4, Intel i7-4790K @ 4.4Ghz, 32GB RAM, 8x 3TB 7200rpm HD, 2x 5TB 7200rpm HD, 4x 256GB SSD, 4x 500GB SSD, unRAID Pro 6.3.0-rc6 (Dual Parity + SSD Cache).
Old 01-28-2017, 10:18 AM
EnterNoEscape is right about the cause. I sent you a PM with some SSL background and a trust chain you may use if you're using my server as a test. (Let's Encrypt Authority X1 is the issuer.)
Old 02-18-2017, 05:58 AM
jonnydeath jonnydeath is offline
I did this with my skill for ssl:
input = input.replace(/\s+/g, '-');
var https = require( 'https' );
var options = {
host: ipAddress,
port: port,
auth: authString,
path: basePath + 'Watch&1=' + input + '&2=' + extender + '&encoder=json',
rejectUnauthorized: false,
requestCert: true,
agent: false
var request = https.get( options, function( response ) {
Old 04-30-2017, 04:57 PM
mike1961 mike1961 is offline
I'm not sure if this is a sage question but I too wanted ssl for my web server application I wrote. I used the free stunnel app which gives 128bit SSL and it's free at stunnel.org. It's really easy to set up and allows you to easily select your unencrypted port (ie: say port 5000) and then it forwards to to a port you configure to be encrypted (ie: say port 5001). Then you can just port forward 5001 on your router for external use. It's quick and easy to set up and you can get SSL going in as little as 5 minutes. I'm not sure if that's what you might be looking for but it can make any port SSL this way.
Old 05-02-2017, 02:03 PM
tmiranda's Avatar
I was trying to go the other way. I need my app to establish an SSL connection.
Old 05-08-2017, 10:59 PM
I'm confused - if your app is a web server then you can use stunnel with your app and then you can use any web browser such as internet explorer, firefox, etc. Otherwise, if you are writing your own web server and client (rather than using a web browser as the client) then you might want to look into the chilkat ActiveX controls for AES encryption at chilkatsoft or just write your own encryption routines before sending the data over the socket. Chilkat has a ton of activex controls and are reasonably price with royalty free redistribution.
Are you trying to use SSL with your app so that users can use a web browser or are you also providing the client app as well? That will determine whether you can use the free stunnel app.
Also, I'm trying to understand what your app is for? Is it for sagetv or something else?
Old 05-09-2017, 06:40 AM
The app is a client that needs to connect to web servers over SSL.
Old 05-09-2017, 06:22 PM
I'm not sure how to advise him in that situation. I would think there would be certain protocols the server would expect.
HOWTO for upgrading 6.6 -> 7.1.9 ? Grant.Edwards SageTV Linux 2 08-27-2011 04:35 PM
Howto get two HD-PVR working? zoltran Hardware Support 19 01-29-2009 01:51 PM
Network Encoder HowTo bcjenkins SageTV Software 15 06-28-2007 06:02 AM
WinAmp howto? moamoa SageTV Customizations 5 11-29-2006 06:21 PM
Sage SDk? howto? oshapir SageTV Beta Test Software 1 05-07-2004 07:29 AM
