SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
UPNP issues w/ hd200
i want to create a upnp profile in TVersity for the hd200.
does anyone know the name given by the hd200 in response to a query from tversity? for example, the profile for the pinnacle 200 starts with <friendlyName>Pinnacle ShowCenter 200</friendlyName> <manufacturerName>Pinnacle</manufacturerName> <modelName>ShowCenter 200</modelName> i assume we need to know the exact response of the hd200 for the 2nd and 3rd line above thx Last edited by cat6man; 03-07-2009 at 09:45 PM. |
upnp issues - tversity
a wireshark log has the hd200 sending out a broadcast message at startup identifying itself as "STP-HD200" so hopefully a profile for the hd200 could be built with that name, i think?
i found something strange with upnp TVersity and the hd200. first, my files are in TP format which the hd200 doesn't recognize yet (but should be trivial to fix). i don't know what profile TVersity is assigning to the hd200 here (it is set to automatically select what it thinks the correct profile should be) but when i browse folders via upnp tversity server, files less than 1GB show up as MPG extensions (and play) but files over 1GB show up as small M3U extensions...........huh? anyone know: 1) what this *.m3u stuff is about? 2) how to built a correct tversity profile for the hd200? eventually (soon i hope), the hd200 will support TP extensions directly an the upnp profile will work seamlessly with that as well thanks |
follow up:
1. looks like large files show up as small ghost m3u even if the file is TS format, which the hd200 can play (previously saw this for TP files which hd200 doesn't yet recognize as video) 2. also looks like upnp m3u problem is observed with playon/hulu (other thread) so there may be a root cause to both of these problems 3. anyone with a hd100 able to check this out for comparison? |
Unfortunately the HD100 doesn't have a standalone mode and therefore no UPnP support.
-Craig |
bug report submitted for upnp problem with large >2GB files................reproduced and fix to be in next release per developers..........gee these folks are fast!
keeping my fingers crossed.
UPnP Support From HD200? | cncb | SageTV Studio | 2 | 03-07-2009 05:40 PM |
myihome upnp server | HookedOnTV | SageTV HD Theater - Media Player | 2 | 01-01-2009 02:01 PM |
UPnP support for extenders? | salsbst | SageTV Studio | 0 | 01-08-2008 06:29 PM |
Sagetv UPNP Server | fyodor | SageTV Customizations | 13 | 07-07-2007 10:41 AM |
uPnP | djmaxwell | SageTV Software | 1 | 03-17-2006 09:15 PM |
