Help installing HD-PVR on Win2003 SP2 server
Sorry... this is off topic but I was looking for an active thread... I just got my HDPVR and I'm unable to get it installed successfully on my Win2003 SP2 server. Seems to work fine on my WinXP workstation.
I noticed that at least one of you has Win2003 SP2 in your setup... anything specific anyone can think of that might cause the driver not to install correctly? * moved to its own topic * |
What exactly is the problem you are encountering?
You should be able to use the WinXP drivers. I run Windows Home Server which is essentially Win 2k3 SBS at it's core. |
I'm running the latest SageTV Beta + HD-PVR on my 2003 SP2(32-bit) server with no problem... I've used various HD-PVR drivers and they have all installed without a hitch.
Remote options on Win2003 Server w/ display | M3_boogie | Hardware Support | 5 | 03-08-2009 07:17 PM |
Direct video output from SageTV/Win2003 server possible? | M3_boogie | SageTV Software | 6 | 02-24-2009 08:36 PM |
Lost audio after installing SageTV with XP-Pro sp2 and PVR-350 | norseman1 | Hardware Support | 0 | 05-10-2006 08:04 PM |
SageTV 4.1 is crashing Win2003 server | SethV | SageTV Software | 7 | 02-03-2006 11:16 PM |
VMR9 not working after installing SP2 | EncoderHouse | SageTV Software | 10 | 08-28-2004 10:56 PM |
