Old 12-09-2007, 11:10 PM
Wirenut Wirenut is offline
A "Void" API
So my imported STV written for Sage Version 4 has this call....
From the Sage API Call Weblist;
PlaySound
public void PlaySound(java.lang.String SoundFile) Plays the specified sound file (used for sound effects, don't use for music playback)
Parameters:
SoundFile - the path of the sound resource to play back
It's from Bohica's HAL Home Automation STV...
PlaySound(halVMDir + "\\" + GetElement(ListItem, 5))
...it is used to play back voicemail from the server. It just stopped working around the version 6 upgrade. There is probably a new way of doing this. The old method worked fine. The voicemails are tiny .wma files... but could be .wav if needed.
I would like to know the best way to replace the old PlaySound call with a new similar API call. ...without stopping or discarding a currently playing media file.
Peace,
Wirenut
Old 12-09-2007, 11:18 PM
GKusnick's Avatar
GKusnick GKusnick is offline
PlaySound still works. I can't say I ever tried it on WMA files, but it definitely works on WAVs.
If it suddenly stopped working, I'd suspect either your path calculation is messed up, the file isn't where you think it is, or you've switched clients from SageTVClient to Placeshifter or MVP. In the latter two cases, the sound will play on the server's soundcard, not on the client.
My suggestion would be to do some more troubleshooting via Expression Evaluator using known good file paths to narrow down the cause of the problem.
-- Greg
Old 12-09-2007, 11:31 PM
Greg already said more than I was going to suggest, so I'll just add that "void" just means the call doesn't return anything, not that it was removed.
- Andy 13,000
Old 12-10-2007, 11:45 AM
Okay.
I'll keep looking in other directions as you mentioned.
Thanks a lot,
Wirenut
DVP API support andmalc SageTV Linux 4 08-24-2007 05:33 PM
Console outputting, and stopping playback via the API. beelzerob SageTV Studio 9 08-02-2006 04:29 PM
Renaming Sage recordings through API jominor SageTV Studio 4 03-07-2006 05:46 AM
Studio API question lotus298 SageTV Studio 2 12-07-2005 01:01 PM
Sage API RMI Server drjava SageTV Customizations 11 11-23-2005 11:35 AM
