Old 04-07-2005, 09:43 AM
Methius's Avatar
Methius Methius is offline
Wake on USB, How to?
Hello,
I've made an HTPC which works beautifully (S3 suspend, pvr works great) thanks to this forum. I still have one little problem.
The motherboard in the pc is an Asus A7V880, which should support Wake on USB.
http://www.asus.com/prog/spec.asp?m=A7V880&langs=01
I adjusted the jumpers according to the manual, to enable USB Wake Up.
http://www.asus.com.tw/pub/ASUS/mb/s...791_a7v880.pdf
I then went to the BIOS to enable USB Wake Up, only to find that there was no such option. The only options available were:
Wake on - Ring, -PS/2 Mouse, -PS/2 Keyboard, -PCI Device, -Event
Furthermore, I couldn't select the "Let this device wake-up the pc when in stanby" mode in the device manager settings of the USB Host.
I upgraded to the last bios for this m/b and installed the latest 4in1 drivers from VIA to get it to enable, but no luck so far.
I just want my remote to be able to wake up my pc when in suspend, can anyone help me?
Thanks in advance.
Old 05-05-2005, 03:44 PM
infiniti_guy infiniti_guy is offline
ASUS MoBo uses the jumper settings only. No BIOS mod needed.
