SageTV for unRAID/Docker Discussion related to SageTV for unRAID/Docker. Questions, issues, problems, suggestions, etc. relating to SageTV for unRAID/Docker should be posted here. |
Comskip Donator
Hi, I am trying to install the donator comskip.exe file on my unRAID system and could use some help.
For one thing, do I only need the comskip.exe file, or the comskipGUI.exe as well? I don't know how to add or overwrite a file in this OS and I am on a remote PC logging in. Also, not sure how to stop SageTV docker while still seeing the file structure? Any help is appreciated. Thanks, |
Thank you for the quick response - I don't think I have needed it to this point so I did not know. Also, the _097 version of the .exe file seemed much larger than the .exe file on my unRAID SageTV docker - but who better to know than you!
Thanks for everything - my system is running very smoothly and I think a testament to how good things run is this forum is not that active. |
Before I found this thread I went ahead and downloaded the latest donator version 82 and replaced the v80 that had installed with docker. Should I anticipate any issues with that?
Been years since I messed wityh comskip on any OS. Where do I go in UNRAID to confirm it's running, or to set the number of concurrent instances? Or is that done via the Sage UI?
[size=1]Current Server:V9 UNRAID Docker, SuperMicro x9dri-LNF4+, 32 GB ECC, 2x Xeon e5-2660v2, storage array 6TB, 2 Dish r5000HD tuners, 1 HDHomerun Quatro, 1 HDHomerun Extend 4 Nvidia Shield TVs with Miniclient |
Comskip | NetworkGuy | SageTV v7 Customizations | 2 | 01-09-2012 07:39 AM |
comskip/comskip monitor - firewall?/SageMc | spvoyek | SageMC Custom Interface | 2 | 12-17-2008 01:35 PM |
comskip help please | eclas | SageTV Customizations | 8 | 09-28-2008 07:17 AM |
Comskip in V4 | amg | SageTV Customizations | 0 | 11-02-2005 10:41 PM |
