Old 10-11-2018, 01:11 PM
HuMan321's Avatar
HuMan321 HuMan321 is offline
Recording Issue
Hi,
I am having some issues with recordings with my SageTV UnRaid system. The latest is an example of what I have seen a few times now.
I was recording the SeaHawk/Rams football game and had the recording padded for 1 hour extra (2-6PM). I went to watch the game about 5 hours after it started and noticed it still showed it was recording. I started the recording and it went straight to 6PM my time to start and the recording bar was red and would not let me backup to the game. I went to my PC to look at the recording and saw that is was only 2GB or so and was only the local news (6PM) when I played on my PC
It seems like the NFL game was overwritten when the system kept recording? This has happened a few times to cut off the very end of a game and if you are a sports fan you will understand how annoying this is.
Also in case it is important I went on the SageTV system to stop the recording. It did not have the option to "stop the recording" and only had record this program etc.
Any thoughts are appreciated.
Old 10-11-2018, 03:21 PM
Not sure about your recording issue, but you have got to install this:
https://forums.sagetv.com/forums/showthread.php?t=57364
It keeps the recording going until the game is over--you don't have to manually add any padding. To me it's a must-have for sports fans.
Old 10-11-2018, 03:26 PM
HuMan321's Avatar
Thank you - I actually have this installed and I know what you mean - it works great. I put the padding on after it "did not" work a couple times in the past and cut off the ending.
Wonder if there is a conflict from manual padding and SRE?
Old 10-11-2018, 09:54 PM
wnjj wnjj is offline
If you had saved all of the log files after it happened we could trace it. Somehow it got thinking you were watching “live tv” and deleted the files that were already “watched.” Did you by chance have a second client watching it the whole time? Was it a favorite or manually scheduled recording. Were there spare tuners at the time?
Old 10-12-2018, 08:52 AM
HuMan321's Avatar
It happened Sunday so not sure if the log files are valid still? What log file am I looking for?
No 2nd client watching this
It was a favorite with 60 minute padding and I also rum SRE
There were spare tuners available
Thank you,
Old 10-12-2018, 09:12 AM
Thank you,
sagetv_*.txt in the directory where the Sage executable is. There are 4 of them with sagetv_0.txt being the most recent and sagetv_3.txt the oldest. This many days later it’s likely well past but if you have this issue again or can recreate it on another show you don’t care about, save them off somewhere.
Old 10-12-2018, 07:04 PM
graywolf's Avatar
graywolf graywolf is offline
There is parm in the sage.properties file that controls the number of log files. The default is 4. I have mine at 30 since I have missed stuff in the past when it was 4
Old 10-15-2018, 02:29 PM
HuMan321's Avatar
I had another incident where a recording of a football game was all red on time bar and not viewable. It was the Seahawks/Raider game yesterday and it started at 11AM and with the manual 30 minute padding I have on it ending at 230PM. Not sure what to look for in the log to see what happens to the recording. Any help is appreciated.
Seahawk.txt
Old 10-15-2018, 03:04 PM
Attachment 17022
That .txt file is messed up. Can you .zip and attach the original(s)? Be sure they span the time from before 11am to after 3pm.
Old 10-15-2018, 04:38 PM
HuMan321's Avatar
I hope this works
Old 10-15-2018, 05:34 PM
Well here's the "what". I'm looking further into the "why".
Sun 10/14 14:30:00.077 [Seeker@3e9643f7] Doing pre-emptive file format detection on recording MediaFile..../var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts
Sun 10/14 14:30:00.077 [Seeker@3e9643f7] Marking format detection as failed for:MediaFile[id=4609987 A[4514267,4514180,"NFL Football",34435@1014.11:00,180,T] mask=TV host=tower encodedBy=HDHomeRun HDHR-US Tuner 10157CAA-0 on 192.168.0.15:9000 KNINDT format=MPEG2-TS 0:00:00 0 kbps [] /var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts, Seg0[Sun 10/14 11:00:00.004-Sun 10/14 14:00:03.199], Seg1[Sun 10/14 14:25:01.599-Sun 10/14 14:30:00.058]]
Sun 10/14 14:30:00.170 [Seeker@3e9643f7] MediaFile verification deleting segment this=MediaFile[id=4609987 A[4514267,4514180,"NFL Football",34435@1014.11:00,180,T] mask=TV host=tower encodedBy=HDHomeRun HDHR-US Tuner 10157CAA-0 on 192.168.0.15:9000 KNINDT format=MPEG2-TS 0:00:00 0 kbps [{SeriesInfoID=3071077}] /var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts, Seg0[Sun 10/14 11:00:00.004-Sun 10/14 14:00:03.199], Seg1[Sun 10/14 14:25:01.599-Sun 10/14 14:30:00.058]] segfile=/var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts
It's failing to detect the format and then deleting the "bad" file. I'm not sure what it's looking for it if it's optional. I'm tracing the code that does this in MediaFile.java.
Old 10-15-2018, 05:52 PM
Any idea what plug-in is causing this?
Sun 10/14 14:29:07.988 [Thread-1665@6dea067f] CD: StreamGetter: Duplicate lines = 4:/var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts: Can not open file
I wonder if it somehow messed up the file. I noticed when the file first started recording that the format detection passed:
Sun 10/14 11:00:04.757 [Seeker@3e9643f7] Doing pre-emptive file format detection on recording MediaFile..../var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts
Sun 10/14 11:00:04.758 [Seeker@3e9643f7] Using internal format detector first for: /var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts
Sun 10/14 11:00:04.763 [Seeker@3e9643f7] File Format Parsed-2a /var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts=MPEG2-PS 0:00:01 5490 kbps [#0 Video[MPEG2-Video 59.94006 fps 1280x720 16:9 progressive id=e0]#1 Audio[AC3 48000 Hz 6 channels 448 kbps MAIN idx=1 id=bd-80010000]#2 Audio[AC3 48000 Hz 2 channels 192 kbps idx=2 id=bd-81010000]]
Sun 10/14 11:00:04.769 [Timer-11@787443fc] Doing pre-emptive file format detection on recording MediaFile..../var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts
Sun 10/14 11:00:04.882 [Seeker@3e9643f7] File Format Parsed-2b /var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts=MPEG2-PS 0:00:01 5490 kbps [#0 Video[MPEG2-Video 59.94006 fps 1280x720 16:9 progressive id=e0]#1 Audio[AC3 48000 Hz 6 channels 448 kbps MAIN idx=1 id=bd-80010000]#2 Audio[AC3 48000 Hz 2 channels 192 kbps idx=2 id=bd-81010000]]
Old 10-16-2018, 07:33 AM
HuMan321's Avatar
I do not know which plugin it might be - I don't have a lot installed.
Live PVR Data Server?
Sage Recording Extender?
These two are related to auto extending and might be issue with my manual padding?
Thank you for all your time and help!
Old 10-16-2018, 12:49 PM
A little more info:
1. The Seattle game was only ever set to record from 11-2, not 2:30.
Sun 10/14 11:00:02.455 [Seeker@3e9643f7] Seeker.startRecord(HDHomeRun HDHR-US Tuner 10157CAA-0 on 192.168.0.15:9000 A[4514267,4514180,"NFL Football",34435@1014.11:00,180,T], currTime=Sun 10/14 11:00:00.003) currRecord=null switch=false
Sun 10/14 11:00:02.457 [Seeker@3e9643f7] MediaFile created subfile:/var/media/tv/NFLFootball-SeattleSeahawksvsOaklandRaiders-4514267-0.ts MediaFile[id=4609987 A[4514267,4514180,"NFL Football",34435@1014.11:00,180,T] mask=TV host=tower encodedBy=HDHomeRun HDHR-US Tuner 10157CAA-0 on 192.168.0.15:9000 KNINDT format=MPEG2-TS 0:00:00 0 kbps []]
2. Right as it was completing this recording, a plugin added a manual, timed recording for 11-2 for the same show. "AsyncChannelSetRecordingTimes" is the thread that comes from the plugin API.
Sun 10/14 14:00:00.198 [AsyncChannelSetRecordingTimes@31a15568] Called Seeker.timedRecord(startTime=Sun 10/14 11:00:00.000 stopTime=Sun 10/14 14:00:03.198 stationID=34435 recur=0 recAir=A[4514267,4514180,"NFL Football",34435@1014.11:00,180,T] hostname=null
Sun 10/14 14:00:00.199 [AsyncChannelSetRecordingTimes@31a15568] Added:ManualRecord[A[4514267,4514180,"NFL Football",34435@1014.11:00,180,T] time=Sun 10/14 11:00:00.000 dur=3:00:03]
3. Since it was the same show but a higher-priority manual recording that already ended, the system got wadded up and deleted the original without recording the new manual one.
I'm guessing something is wrong with whatever plugin that injected that manual recording. Don't the recording extending plugins just add padding and not create new recordings?
Also, the "CD: StreamGetter" message above is from Commercial Detector and isn't the cause but instead another victim of the missing file.
Old 10-16-2018, 01:15 PM
HuMan321's Avatar
This is all very interesting. I have an NFL football favorite setup with 30 minute padding. I added the padding because the SRE or Live PVR plugin did not work extending a game that went long.
As I understand these plugins to work they only pad and do not record or re-record.
The game last night did something funny too and I will get that txt file when I get home in case it provides additional clues.
Are you familiar with these two plugins I listed to know if I need both fro sports padding?
Thank you for all your help!
Old 10-16-2018, 04:14 PM
HuMan321's Avatar
Here is a txt file for the San Francisco/Green Bay game last night - It started at 6:15 and normal end would be 9:15PM. I had 30 minute pad and something happened around 9:39 or so where the past recording of the game went from watched color to red on the time bar and the file was gone. I was watching this game about 20 minutes behind or so.
I attached a screenshot of the recording after it turned red on time bar - The recording is showing only 6 minutes long although the entire game was there and viewable before 9:39
Old 10-16-2018, 04:33 PM
If you're not using SRE why not remove it and the LivePVR data? Although they've been rock solid for me on NFL/NHL/MLB.
Old 10-16-2018, 05:01 PM
HuMan321's Avatar
I was not using it because it failed me once and I was not sure if it was up to date with current development.
Do you need both of these plugins for auto padding of sports events?
Old 10-16-2018, 06:31 PM
Yes, you need both. But I'm saying if you're not using it remove both and see if it fixes your manual padding issues. There might be a conflict.
406: recording soon issue Gustovier Phoenix 2 09-27-2011 12:18 PM
New to Sagetv - Recording Issue Rockhopper SageTV Software 6 01-07-2011 07:26 AM
ATI 650 Recording issue ptaylor Hardware Support 2 10-24-2006 01:11 AM
having a recording issue ... ViAo Hardware Support 10 10-23-2006 09:58 PM
