Need suggestions for SageTV and PVR350 Cards
I've been using SaveTV for a few years. The configuration consists of 2 Haupppauge PVR350, 2 Dish 311 STB, an Intel DG865GLC motherboard, a Pentium 4 3Ghz CPU and 2 gb of ram. I have no add-on video card on this PC. Tuning of the Dish 311's is done with a USB-UIRT and the Hauppauge 45-button (?) remote.
I also have a Hauppauge HVR1600 74041LF card which I've tried to get running in a similar PC but gave up for now because the video was jerky. Until now I've used the TV-out on one of the PVR-350's to view both live and recorded video on a standard TV. The old TV finally died and I bought a new Vizio VP322 32" plasma TV. I've tried connecting the PC to the RGB inputs of the new TV, but the video was jerky and not as good as the results I get when I connect the TV-Out of the PC to the AV inputs of the TV. I've tried installing an Nvidia GeForce 7300 GT video card from another PC, but this seemed to make the video slightly worse. I've also tried installing SageTV, the 7300GT video card, and the two PVR350 cards in another DG865GLC motherboard with an identical CPU and memory configuration with the same results. I've tried everything I can think of to get this setup running. Any knowledgeable suggstions would be greatly appreciated. Failing getting the current setup working, I would appreciate recommendations for a no-BS, guaranteed to work, motherboard/CPU/memory/Video solution. I would like to use the two PVR350's and the HVR1600. I don't have a whole lot of money to spend on this, but I sure would like to get it running.
Ed Sims |
You could keep your current PC & tuners and just get the new SageTV STP-HD200 HD Theater. It's hardware decoder will handle playback duty, so the old PC should be fine for a while longer. It will also play the HD recordings from the 1600 & other tuners, which the 350 can't do.
Andy,
Thanks for the fast reply. From what I've read so far this sounds like an excellent and affordable solution. Is an owner's manual posed anywhere online? Thanks again
Ed Sims |
My sig lines have a link to the HD extender FAQs & the downloadable manual is linked in the first post there.
Thanks for your help. I found the docs and ordered one.
Ed Sims |
which other personnal recorder software allow the PVR350 S-Video Output to work? | JonZ | Hardware Support | 7 | 07-04-2007 05:51 AM |
End of recorded show crashing SageTV w/350 | julesjohn | SageTV Software | 83 | 09-02-2006 02:00 PM |
Any other hardware decorder cards? | kevthor | Hardware Support | 3 | 12-14-2005 05:57 PM |
Playback problem with PVR350 generates Blue Screens in V4 | Nadim | Hardware Support | 1 | 12-08-2005 12:33 AM |
Wrong output resolution for PAL PVR350 cards when using OSD? | vsonerud | SageTV Beta Test Software | 5 | 01-26-2004 10:27 AM |
