Old 11-27-2017, 01:03 PM
Taddeusz Taddeusz is offline
Plex Including Comskip Support?
I'm not using the Plex Pass versions so I don't know yet what it means but this one liner appears in the latest change log:
(DVR) Added functionality to remove commercials from recorded content (#5633)
Will be interesting to see what this means.
Old 11-27-2017, 01:11 PM
So I switched to the Plex Pass version to check it out. Here is the option in the DVR Settings. Apparently it will completely remove detected commercials from the video. That's kind of scary considering how inaccurate comskip can be at times.
Old 11-27-2017, 02:06 PM
Is this just if you are using Plex as a DVR and on TV that Plex is recording? Or will it work on any video file? From that attached image it looks like it is a DVR setting.
Old 11-27-2017, 02:20 PM
I'm not entirely sure. I switched back to the public branch. If I had to make an educated guess I'd have to say it's part of the DVR functionality.
Old 11-27-2017, 03:20 PM
It is part of the DVR function ... you set it when you setup your recording to cut commercials.
I run Plex on my WD PR4100 and I have been testing it so far accurate commercial cuts not sure what they are using but it works... Very low CPU usage on my NAS.
Old 11-27-2017, 03:46 PM
SHS's Avatar
SHS SHS is offline
Version 1.10.0.4516 New
(Web) Updated Plex Web to 3.27.1
(Live) Added the ability to seek within an active recording, with client support
(Transcoder) Support for hardware decoding of 10-bit HEVC
Still No program guide Boooo
Old 11-27-2017, 04:06 PM
They are using Comskip donator version.
Old 11-27-2017, 09:23 PM
panteragstk's Avatar
Got a link? Am curious if we would be able to fool it into reading our .edl files.
Old 11-28-2017, 07:46 AM
But .edl files work at playback - it looks like they are running a process at, or just after, recording that actually edits commercials out of the video file.
Old 11-28-2017, 08:14 AM
That is the impression I get from this.
Old 11-28-2017, 01:39 PM
Yeah, not sure why they wouldn't just mark the commercials and allow skipping/seeking instead of cutting them out.
Old 11-28-2017, 03:55 PM
I don't know if this still matters but that likely would give them more cover if they get sued by Hollywood. Didn't ReplayTV get sued into bankruptcy due to commercial cutting/skipping?
Old 11-28-2017, 04:14 PM
SHS's Avatar
SHS SHS is offline
You do know that TiVo and Dish have it
Old 11-28-2017, 04:30 PM
But my understanding is that the content doesn't get deleted and you have to manually push a button to skip through the commercial break, at least with TiVo. Maybe DTV is different. This is from TiVo's website (see bullets 3 and 4 in particular):
SkipMode - Things to know
  • For popular shows, our team usually has SkipMode information updated for a show within 1 hour of the show ending.
  • SkipMode only applies to recorded programs, and only to recorded programs which have been marked for commercials by our team. SkipMode can't fast-forward live television.
  • SkipMode requires you to use the remote to skip sections. The TiVo device itself does not automatically skip through the commercial breaks.
  • When you use SkipMode, the commercial breaks are being skipped. The commercial breaks have not been removed from the program.
Old 11-28-2017, 04:56 PM
It works really well on a TiVo for the shows which are supported. It's almost near instant. The way it works on SageTV is very similar.
Old 11-29-2017, 09:36 PM
True. That's my worry. A lot of my shows would be ruined if the file was cut and the original deleted.
Old 12-05-2017, 09:52 AM
farscapesg1 farscapesg1 is offline
As a Plex DVR convert, I'll be looking forward to testing this out on a few non-important recordings but I'm not holding my breath. Instead of automatically cutting the commercials, I wish they would improve their chapter marker support (I think IOS devices are the only ones that support chapter markers outside of movies). Having used both Showanalyzer and Comskip over the years with SageTV, I never felt like either did a good enough job of detecting commercials to cut them completely and always configured my SageTV setup to show the commercial blocks but turned off automatic skip because too often I would have to skip back/forwards slightly anyways.
I will say one thing about the Plex DVR... I thought losing the EPG would be a big deal but for our use it has pretty much been a non-issue. Even with SageTV we rarely looked at the guide as we don't do any channel surfing. For us, set and forget favorites and move on. If there is a new show we want to record I just set a reminder on my phone to check the Plex "guide" that day and set a series recording.
WoW Plex add direct 3rdparty TV Tuner support SHS General Discussion 1 06-07-2017 08:42 AM
Plex 4.0 - better peruse the Plex.forum before updating.... tvmaster2 General Discussion 18 08-17-2015 10:16 AM
SageMC questions including FanArt support ?'s heffneil SageMC Custom Interface 5 03-27-2009 06:50 PM
STV Import: Comskip Playback w/ support for EDL sundansx SageTV Customizations 126 10-04-2007 12:20 PM
v3.0 Original STV with COMSKIP support JasonJoel SageTV Customizations 4 07-24-2005 04:32 PM
