Old 02-22-2021, 01:11 PM
tvmaster2's Avatar
SageTV acting up again during program guide changes
I used to have this problem, but never figured out why it stopped happening, but now it's started happening again. grrr.
When the TV guide listing roll through a program change (usually at the top or bottom of the clock), and I'm watching 'LIVE', SageTV server software halts, chokes, and often needs the channel to be re-selected manually in order for viewing to continue.
Also, you can't rewind to the start of the show - it's as if Sage doesn't realize it started five minutes ago.
Devices used that are acting up: HDPVR 1, and a Cisco set top cable box.
I don't think the HDPVR power supply is the problem, since I'm using the 5v, wired to my PC molex method.
Anyone else have this problem?
Old 02-24-2021, 01:34 AM
yup, I've seen this happen. Don't know why, wish I could solve it.
Also using HDPVR and a Shaw STB (Motorola DCX-3200m).
Old 02-24-2021, 06:47 AM
jvl711's Avatar
jvl711 jvl711 is offline
This seems like what I have been investigating in the Android Client thread. I wonder if this is related to the fast_mux_switch setting. This tries to make the switch from one file to the next seamless to the client.
How are you playing back the content? Is transcoding involved at all? You could try turning off fast_mux_switch. It would just add some delay when the transition occurs.
I would like to hear more info, it may be relevant to the development I am doing.
Josh
Projects I am currently maintaining
SageTV Andoid Client
Media Format Parser Plugin
JavaFFmpegLibrary
If you like the work I am doing and would like to support it you can become a Patreon member.
Old 02-24-2021, 09:35 AM
tvmaster2's Avatar
Josh
Sorry, I wasn’t clear on viewing method. I’m actually watching LIVE tv on my SageTV server via the Sage software, as opposed to using a media extender. Actually, I’ll try that today - rolling through a SageTV, EPG tv guide program change, LIVE, on a media extender.
And, I’ll try it via my two, tuner setups to see if there’s a difference (HDPVR with Cisco setup box and cable tv VS. Hauppauge Colossus / Satelite).
If you noticed my profile, I’m running W7, 32 bit.
Old 02-24-2021, 09:56 AM
wnjj wnjj is offline
The fast mux switch setting applies no matter what playback device you’re using since it’s a recording setting. Give that a shot first. Set “seeker/fast_mux_switch=false” in sage.properties.
Windows Installer
Old 02-24-2021, 11:07 AM
tvmaster2's Avatar
interesting, ok. I’ll give that a try. thanks
Old 02-24-2021, 04:54 PM
jvl711's Avatar
Please report back. I am interested in what you see.
JavaFFmpegLibrary
Old 02-24-2021, 10:42 PM
tvmaster2's Avatar
early testing seems to indicate the HDPVR/cable box a bigger problem. After the properties tweak, Colossus/Satellite box rolls through flawlessly. The HDPVR/cisco box still gets a bit confused at a TV guide program change.
Makes no sense. Does it?
Old 02-25-2021, 09:50 PM
fidget's Avatar
fidget fidget is offline
Can you monitor your CPU usage in both cases? I am curious if you get spikes in the HDPVR/cable box case and not with the Colossus. I assume that both are recording h.264 format video.
DVD Storage: 24 TB
Clients: 3
SageTV Extenders:5
Old 02-27-2021, 09:54 AM
tvmaster2's Avatar
Sure - I can even take some photos of the output. What am I looking for exactly, usage wise? There does seem to be a spike when a guide change occurs. I use the 'Great - H.264 3.8GB Hr' record setting, and both my tuners output 720p to Sage.
Old 02-27-2021, 02:14 PM
fidget's Avatar
How big is the spike? I would expect you to be hitting 100% when you see the problem. If you can record the same program from both sources and only the HD-PVR shows the problem, you can compare the two video files to see what is different. One may be recording at 1080i by mistake.
DVD Storage: 24 TB
Clients: 3
SageTV Extenders:5
Cant get SageTV to download program guide data Curtis M SageTV EPG Service 1 05-05-2010 12:17 PM
Sage Acting Weird, Then Lost All Data In Program Guide? PeteCress SageTV Software 7 06-19-2009 05:33 PM
SageTV - Program Guide Strange Behaviour zzmystique SageTV Beta Test Software 2 04-13-2009 05:13 AM
SageTV V6 Program Guide empty and not updating JasonEngel SageTV EPG Service 2 03-20-2007 08:40 PM
How to disable the popup window in the program guide? How to keep the program guide? metropole SageTV Software 8 05-18-2006 06:25 PM
