SageTV United Kingdom SageTV and SageTV Recorder Users from the UK - This forum is for you to post about specific issues using SageTV software in the UK. |
Homeland Episode numbers
Hi all,
I'm using DigiGuide for my EPG (for OTA DVB-T and DVB-T2). I've noticed a problem with the episode number of episone 1 of the new season of Homeland starting on Sunday (channel 4, 9pm). In my guide (from DigiGuide), it says: Homeland, Episode: Season 2 - Episode 03 - The Smile it should say: Homeland, Episode: Season 2 - Episode 01 - The Smile The Digiguide application run on the STV server says Episode 01, but somewhere between that and STV it turns in to Episode 03. I noticed that there were some disparities in the episode numbers in season 1 of Homeland. I only noticed these after the air date, and put it down to faults with DigiGuide. Now I've spotted this before the air date, i'm not so sure. ![]() Has anybody else got this problem? Thanks in advance mevans
Server: ASUS P7P55D, Core i5 750 2.66GHz, 4GB RAM, Antec Three Hundred, 1x TBS 6284 PCI-E DVB-T2 Quad (OTA HD 'Freeview'), 2x HD Homerun dual tuners (OTA SD 'Freeview'), WHS OS installed on Seagate 250GB SATAII, Recording to 9TB Storage Pool (64k clusters) SageTV version: 7.1.9 HDHomerun's plugged into mobo NIC via giga switch 2nd NIC to home network Program Guide: DigiGuide Birtles Grabber XMLTV Importer for SageTV Clients: Two HD200, One HD300, Client on PC, Placeshifter on PC |
This Sunday coming ?
This is a copy/paste from the web server : Homeland Episode: Season 2 - Episode 01 - The Smile Airing: 07-Oct-2012 21:00 - 22:05 Duration: 1h 5m Channel: 104-Channel-4 I'm using Digiguide & Stephane's importer
Tecra M5, 2 x HD200, 2 x HD300 2 x PCTV 290e Win 7, Sage 7.1.9, Phoenix 2 STV Stephane's XMLTV Importer, Digiguide, |
Hi there.
Yes this Sunday coming. here is my copy/paste from Sage Webserver: Code:
Channel4 logo Homeland Episode: Season 2 - Episode 03 - The Smile First Run Airing: 07-Oct-2012 21:00 - 22:05 Duration: 1h 5m Channel: 4-Channel4 Description: The second series of the Emmy Award-winning, dark, compelling US thriller starring Claire Danes and Damian Lewis comes to Channel 4. Months after Carrie's expulsion from the CIA and the dramatic events that prompted her to undergo electro-convulsive therapy, the former CIA officer is on the slow path to recovery and has found a degree of peace within the protective embrace of her suburban family. Category: Other - First Run - 2011 Original Air Date: Sunday, 7 October 2012 Stereo Show ID: EP0242570017 Internal details: AiringID=4892852 very odd!! ![]()
Seen this sort of problem from DG2XML before, occasional problems, it's why I use the Birtles grabber with Digiguide.
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.3, tvHeadEnd for recording back end, Emby Clients: 3 Nvidia Shields, 3 FireTV, 3 Win10 Pro PC Clients |
Absolutely, the Birtles is the way forward, I've also wrote a grabber postprocessor in LUA to perform illegal character substitution in the XML.
Automatic Power Off | Squeezeslave | DVB-S Importer | DVB Decrypter & Card Client | Tuner Preroll Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit. ~ Elbert Hubbard |
Hi.
ok, i'll give that a try. I've found this link in one of the 'stickies' at the top of the UK forum, which seams to make sense. Although on the XMLTV GUI Wiki, it gets you to install the DG2XML skin, which sounds a bit odd, if i'm tryin to get away form DG2XML! Just to make things as clear to myself as possible ![]() XMLTV Importer for SageTV, calls Birtles Grabber, which gets it's data direct from the Digiguide for Windows application on my STV server PC. In order to make this switch, i guess i install Birtles Grabber, set it up for Digiguide, and then point 'XMLTV Importer for SageTV' at 'Birtles Grabber' (not DG2XML which is where it currently points). ![]() Thanks
Eddy
Hi Eddy,
Thanks - i'll give that a go! Mevans
Oh, another thing, the Birtles package comes with two executables, the GUI and command line version, of course you have to use the GUI to configure and the command line version for the Stephane importer.
Eddy
OK, thanks.
Here's for an update... I've installed 'Birtles Grabber' and set up (mostly accepted the defaults). Set a password in 'Digiguide' for it's web server (skin set to "web"). Tested 'Birtles Grabber' via it's GUI Checked the output with XMLTV EPG Viewer. Check that the 'Birtles Grabber' XmltvConsole.exe ran from 'Start'/'Run'. Adjusted the settings in 'XMLTV Importer for SageTV' to point at the 'XMLTV GUI' 'data.xml' file. Adjusted the settings in 'XMLTV Importer for SageTV' to point at 'Birtles Grabber' XmltvConsole.exe with no 'arguments'. Ran a manual "Update Guide Data" in 'XMLTV Importer for SageTV', got a load of errors because it didn't know which SageTV channels should be associated with which EPG channel data. I had to remap the "XMLTV Data" column in the "Channel Lineups" section of 'XMLTV Importer for SageTV' Ran a manual "Update Guide Data" in 'XMLTV Importer for SageTV'. this time it worked. On the SageTV webserver, i forced an EPG update. Gave it a minute, and checked the EPG on the SageTV webserver. Homeland on this coming sunday is now displaying correctly as episode 1. ![]() Quote:
Thnaks for your help so far ![]() Mevans
EDIT: I'm a little confused, the fact that it says HDTV means it knows that it's HD. There aren't any more HD tags. Do you mean it doesn't have a pinkish dot against the show in the guide? Last edited by doc; 10-03-2012 at 11:22 AM. |
hi,
I mean that when you get the info on a show, it doesn't have the HD symbol next to the watched or first run symbol. mevans
Are you looking at the guide through the web interface? mine doesn't show HD markers, but the program guide in Sage itself does.
If thats what you mean I'm guessing its a limitation with the web interface Last edited by doc; 10-03-2012 at 01:46 PM. |
![]() I think doc is right, if the importer doesn't read the HD tag you must tick it manually in the channel lineup... Eddy
You must unzip the file under "<Birtles installation dir>/scripts/" and the script will appear under "Postprocessors" tab, also please make sure to change the priority to be below "UK_Digi_ALT_Digi". The script is pretty harsh and not my best example of programming ![]() The script allows you to configure the automatic substitution of the following illegal XML characters: &Amp -> and   -> - Obviously, if you need to add extra substitution you need to change the script, but it should be rather easy to do; at the moment those above are the only illegal characters sometime present in the DigiGuide XML file...intentional? I don't know. Cheers Eddy
Automatic Power Off | Squeezeslave | DVB-S Importer | DVB Decrypter & Card Client | Tuner Preroll Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit. ~ Elbert Hubbard Last edited by routerunner; 10-04-2012 at 12:58 PM. |
Tags |
epg data |
Season & episode numbers in filenames? | MondayTuesday | SageTV Beta Test Software | 8 | 05-09-2011 06:57 PM |
Episode Name Alignment When Using No S or E Numbers | ptzink | Diamond | 5 | 03-17-2011 02:59 PM |
Season/Episode Numbers with 7.1.3 | Narflex | SageTV Beta Test Software | 11 | 03-11-2011 10:45 PM |
add Season and Episode numbers | LoopyWolf | SageTV Customizations | 2 | 09-12-2009 01:41 PM |
Episode Numbers Missing from RT Feed | rickgillyon | SageTV United Kingdom | 31 | 03-29-2007 12:23 PM |
