SageTV EPG Service Discussion related to the SageTV EPG Service used within SageTV. Questions about service area coverage, channel lineups, EPG listings, XMLTV, or anything else related to the service or programming guide data for SageTV should be posted here. |
Error - Invalid EPG Server Licence Key Specified
Just upgraded to version 9 today for the first time. Running on Windows 7 64 bit.
Everything went very smoothly, except when SageTV went to do an EPG update. I'm getting a new system message every few minutes saying Invalid EPG Server License Key Specified. This isn't a fresh install. I just ran the latest version 9 installer over top of the version 7 installation. I then reran the installer immediately and selected "Repair", as a few people on the forum mentioned that could alleviate potential problems. I went into the Video Sources setup to re-enter my SageTV key, but it still says it's invalid. Which key should I be using? I have 3 different keys: my original version 2 key, my version 6 upgrade key, and my version 7 key. Any help would be appreciated. The system message count keeps going up because SageTV keeps trying to do an EPG update but fails to do so. Thanks. |
Best bet is the key you were most likely to have been using previously. my bet would be either the V6 upgrade key or the V7 key. https://forums.sagetv.com/forums/sho...5&postcount=10 Last edited by Monedeath; 02-18-2017 at 10:33 PM. Reason: add link |
Thank you! That did the trick. Editing that file was much easier. It turns out it was my version 7 upgrade key.
Everything else seems to be working so far. Thanks again! |
Did a clean install of v9, then pasted in wiz.bin and PROPERTIES. It is still complaining of no license key, but there is already an activkey file there that had my original purchase of v7 from 2007. I have guide data through 4/8. How do i fix this?
[size=1]Current Server:V9 UNRAID Docker, SuperMicro x9dri-LNF4+, 32 GB ECC, 2x Xeon e5-2660v2, storage array 6TB, 2 Dish r5000HD tuners, 1 HDHomerun Quatro, 1 HDHomerun Extend 4 Nvidia Shield TVs with Miniclient |
k
If you wish to see what I am up to and support my efforts visit my Patreon page |
I apologize for hijacking this thread, but I'm getting the same error message.
And I don't have, or I'm unable to locate this activkey file. If I'm supposed to create this file, what is the file extension?? And what should be in this file? Just the key value?? Just cut and paste what was in my license key email from sage?? thank you for your help.
OS: Win 10 64bit / CPU: Intel Core i5-4690K MB: GIGABYTE GA-Z97X-UD3H-BK (rev. 1.0) PSU: Corasir RM850 RAM: CORSAIR XMS3 16GB 240-Pin (2x8gb) SSD: Samsung 860 EVO 1TB Ceton: Infinitv 4 & 6 / Hauppauge: 1 Colossus Raid Controller: StarTech PCI Express 4xSata Raid 0: 4 WD Black 4TB each |
I'm having the exact same problem after upgrading to v9. I used both Sage license keys I've gotten over the years since v4 and neither works (not using dashes in the key). What am I missing?
Help!
Server: ASUS Q87M-E, Intel i5-4590S, 8GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 9TB disk, 2x HDHomeRun, HD-PVR 1212, Win8.1-64bit, Sage 9 Client 1: HD300 on Panasonic Plasma TC-P50ST60 Client 2: HD300 on Vizio 40" Others: Sage Client & Placeshifter |
The question then becomes, what directory did you place the "activkey" file in? If you wanted to test to make sure you have the right place, you could try to enter A key (say "12345" for example) into sage through the client-side(/video sources) option, then go hunt down the relevant file on your sagetv server. If it was in the correct place after all, you may need to contact SageTV support(yes, it still exists) and question them about the status of the relevant keys. But as it stands, it all becomes moot in less then 2 and a half months as that service goes "buh-bye!" in July. |
ok, activkey was in the directory, maybe it generated when I tried using the EPG entering my license key method, it is listing it like this (which isn't working):
XXXXX-XXXXX-XXXXX-XXXXX-XXXXX It is the same key I've been using since I started SageTV on v6. V9 is still calling it invalid. Am I supposed to include the dashes? Or should it be: XXXXXXXXXXXXXXXXXXXXXXXXX or XXXXX XXXXX XXXXX XXXXX XXXXX thanks. mv |
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
Yes I did...
HD300 IR eyes, V7 server+ client licence | burtonpark | SageTV Marketplace | 0 | 02-16-2014 12:57 PM |
Server licence for client | perf | SageTV Software | 1 | 05-18-2012 10:57 AM |
Migrate server to Linux from Windows, licence question. | makko | SageTV Linux | 7 | 01-31-2012 02:51 PM |
Invalid Directory Error | mplonski | SageTV Software | 0 | 12-14-2010 01:01 PM |
Do i need Sagetv server licence for the 2nd server | grahav | SageTV Software | 1 | 05-29-2006 07:25 AM |
