Old 04-08-2017, 09:40 AM
Best config for MiBox+ FLIRC (and maybe harmony)?
FLIRC arrived yesterday so I'm trying to get my head around the best way to set it up with the MiBox. Goal is to replace sage extenders in a few spots where i need to reduce the number of boxes, and preferably have the same functionality, meaning the Mi does not have enough buttons/remote commands out of the box. Need it to work with either the original sage remotes or harmony.
Am I better off programming the flirc with a full keyboard, then having it learn the IR commands from the orig remote? Or do I use one of the other cfg files like Kodi?
Has anyone packaged this up anywhere for download?
thanks
Old 04-14-2017, 01:21 PM
jhkoenig's Avatar
jhkoenig jhkoenig is offline
Very interested in your plan, because I have exactly the same need to replace some HD200/300s. What OS will you use? Any other bits of wisdom to share?
Thanks for blazing the trail. I'm that guy you hear chugging along behind you.
--John
Win10@16GB RAM, 30TB Disk across 6 disks. 2 Prime tuner units
Sage v9 (64bit) using OpenDCT to control the Primes
2 HD-300s, an Android mini-client, and a Windows client
Old 07-18-2017, 08:16 PM
reccitron reccitron is offline
thanks
btrcp2000, How did you end up setting this up? I just purchased the same Mi box and Flirc and need to get my harmony remote configured. Did you create a configure file?
Old 07-18-2017, 08:46 PM
I have a flirc connected to my mi box, but stopped using it. I find the included remote works very well once u get used to .
Old 07-18-2017, 10:17 PM
I think the wife will complain about having to learn a new remote so I'm going to program the remote
Old 07-18-2017, 10:33 PM
I never followed through with programming once I learned that the mibox won't do vudu hdx, so it therefore won't be replacing the sage/Roku setups soon. It's perfect for rooms that just need sage though, like the treadmill and garage. I just pointed out to the wife that all we really do is move around the menus with th arrows anyway.
Old 07-18-2017, 11:07 PM
I just got the MI Box today so I'm still learning about it. My VUDU app says that it is streaming in HDX.
Old 07-19-2017, 05:36 AM
Interesting. Maybe there's an update I don't know about. It always gave me a nonhelpful error message with no detail. Haven't played with that in a while. I will probably need or eventually, will let you know if I learn anything.
Android MiBox questions wayner SageTV Clients Development 4 02-26-2017 02:32 PM
FLIRC and Android TV (Any Success/Issues) stuckless General Discussion 11 10-15-2016 08:15 AM
Anyone tried a FLIRC with their HTPC wayner Hardware Support 0 01-07-2014 08:29 AM
URC VS Harmony?Harmony (Logitech) VS URC remotes? morikaweb Hardware Support 11 02-25-2008 06:54 PM
Logitech Harmony 680 V. Harmony 688 phenixdragon Hardware Support 4 10-23-2004 12:04 AM
