Possible to run SageTV V9 Linux build on Hyper-V VM?
Hi, I am preparing to migrate my venerable SageTV 7 to SageTV 9 with the EPG shutdown.
My current build is running SageTVserver service on a Windows Server 2012 R2 box and also using this as my front end with the client loaded with SageMC as the touchscreen GUI in the kitchen. I am considering installing the SageTVserver V9 to a Server 2012 R2 Hyper-V VM on the server if this gives me the ability to take advantage Javaheap size increase and leverage the more vibrant Linux open source SageTV developer community... Does anyone know if the SageTV v9 Linux version can be run in a Hyper-V VM? If so, what version would I need to use? My encoders are all Network based...3 HDHomerun, 1 HDHomerun Prime. |
I don't see any reason why it wouldn't work in a VM when all the tuners are network based. I know many people run that way. But I don't know anything specifically about Hyper-V VM.
I run my prod sagetv system v9 under Linux ubuntu in a hyper-v vm and have done so for over a year without issue. I am in every way NOT a linux guy
![]() If you use a Gen 1 vm with ubuntu 12 or 14 it is faily simple. There are added steps for a gen 2 vm...they are well documented but IMHO add little value. k
If you wish to see what I am up to and support my efforts visit my Patreon page |
thank you for the replies!
If I am migrating from Windows Server 2012 R2 SageTV v7 to Hyper-V hosted Linux/Ubunto V9 VM, what are the steps I need to follow to migrate my existing windows V7 configuration to Linux V9? mv |
Why would you run such an old version of Ubuntu?
You might want to consider running unRAID instead of Ubuntu which seems to be what the most active developers are using.
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
He is running in a VM - can you even install unRAID in a VM?
You CAN, but the setup is tricky / complex. I looked into running a Xenserver (as hypervisor) machine for my test machine. After many tries of various combinations, I gave up on hypervisors and set up a second instance of running Unraid natively (the machine in my sig, below, is my Production machine).
Regarding Microsoft's Hyper-V and running SageTV - Yes, it should run OK. I ran such a machine about a year ago, when I investigated VM alternatives. In fact, each time I started the Win10 desktop that was running Hyper-V, SageTV would start right up without problems.
Server:UnRaid;2x Intel Xeon E5; SuperMicro moboard;Also:BM3000 w/ WMC; 2x Ceton ETH 6; OpenDCT SageTV Extender:3x HD200 1x HD300 1xFireTV Sage TV: 9.2 on Java 11, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, Playon All in lovely Drexel Hill, PA |
At this point, I'd be asking what Hyper-V gets you that unRAID doesn't. Seems to me with the docker on unRAID, it can serve so many more functions with less virtualization, it might win out.
This is a bit of a side issue, but the one thing that I would like to get working under unRAID is automated backups of all of the client PCs on my LAN. I started trying to set up WHS 2011 in a VM under unRAID but was not successful in getting it working properly. In an ideal world I would run a docker under unRAID that would be able to do these backups and store them on my drive array. These backups would allow bare metal restores of the OS, which for me is Windows, on the client PCs over the network.
This would allow me to shutdown my WHS box.
It looks like this post may describe how to do this: https://www.sevenforums.com/backup-r...tml#post366798
I know - we have had this discussion before. I prefer to get everything back and running as it was previously, as quickly as possible. With WHS I could have everything back in about an hour, assuming that I had a spare Hard Drive (or in recent years SSD) on hand.
I used to use Acronis True Image Home. It allowed scheduling on the client side, (so if you wanted to stagger backups you had to set different start times on each client), and wake from sleep. I moved to WHS because it was more integrated, handled staggering backups automatically, and was more efficient with disk space. Acronis did let you do incremental and full backups and cleanups.
Acronis is on one of those "every year" release cycles that push you to upgrade every year. I'm not up on its current capabilities, (and it seemed back when I used it that every other year was a buggy release). But I have been thinking about retiring my WHS VM as the backup is the only thing I use it for today. I still have a sour taste from some of the "buggy" releases, (never lost anything, but e.g. the full/incremental/cleanup cycle sometimes crapped out and you ended up with tons of files over time), but maybe it's gotten better. I actually still use it for some things. One thing I still use Acronis to do is "Try and Decide". This is where you can turn on "try" mode and install something or make a change, and then decide later to keep it or revert to how things were before you turned on "try" mode. It's like a VM snapshot except it doesn't persist across a reboot. Both Acronis and WHS have been pretty seamless with restores, although Acronis has other tools that I also still use like secure wiping and migration to larger/smaller disks. I think you can find free tools to do these things as well, though. There's a thread on here about backups with some other ideas (most free).
Home Network: https://karylstein.com/technology.html |
I have used the Acronis disk tools before for stuff like partitioning but I didn't need the backup since I have been using WHS ever since it came out. Does Acronis let you do the backups "in situ" without having to reboot into a special OS to do the backups?
But it looks like Windows may have this stuff built in for Win 7 and beyond so I will check that out first.
k
Thanks - I will look at that. In taking a quick look at the Veeam docs at one point it says that for a full metal restore: "You must have a successfully created recovery image on any type of media: CD/DVD/BD or removable storage device.". That would seem to exclude network backups. But then later on in the docs it does appear to talk about restoring from a network volume. Have you tried this?
I use this for all my PCs plus my host windows 2016 server. I use their Hyper-v version...also free if you use their piwershell script which i do...for all my vm's including my sagetv Linux server. k
Basic Linux V9 Build and Walkthrough - V2 | SageWizdom | SageTV Downloads & Instructions | 19 | 10-01-2017 10:17 AM |
Issue with SageTV 9/Linux Build/SMB/Network Encoders | Jabroni | SageTV Github Development | 15 | 02-17-2017 12:00 AM |
Linux pre-build questions | wayner | SageTV Linux | 20 | 02-08-2017 04:31 PM |
Build SageTV (Linux Specific) + GitHub primer | stuckless | SageTV Github Development | 81 | 09-04-2016 12:27 PM |
Linux Ubuntu 16.04 build error | mwnswiss | SageTV Github Development | 1 | 05-21-2016 02:14 PM |
