Old 03-25-2003, 09:48 PM
ftlee ftlee is offline
Sync Issues...
I am still evaluating your software. I have another issue that I need to overcome. I am using a WinTV PVR-250. I am running svideo and the audio directly into this card. While watching LiveTV, the audio and video are out of sync. It may happen in the recordings as well but, I have not checked. How do you fix it?
Frank T. Lee
Old 03-26-2003, 11:32 AM
Mark Lamutt's Avatar
Mark Lamutt Mark Lamutt is offline
Is the audio out of sync all the time, or just when you change channels? If that's the case, pause the video for a few seconds, and then start it again. Or, skip back or forward and the audio and video should resync. Channel changing currently (especially quick channel changes) can cause a momentary loss of sync.
If it's all the time, there is a setting in detailed setup that will allow you put a delay on the audio stream manually to resync the audio and video. Let us know if that helps, Frank.
Mark
mark@freytechnologies.com
The picture is of my kitty, Myko at 9 months old.
Old 03-26-2003, 11:50 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
The first thing Mark mentions is only valid for Provideo/Creative cards. Not for the Hauppauge cards since they have audio & video hardware encoding.
Correct on the second one.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 03-26-2003, 01:26 PM
Whoops - sorry for the misinformation. As you can tell, I'm currently running on a provideo card. Looking forward to running a 350 as well soon, though.
Mark
