HDHomerun UK - does not find channels during scan
I've just tried setting this up on SageTV in the UK. I have run HDHomeRun setup, and it detects the dual tuners and scans and finds the channels. I have set it to Digital Antenna and SageTV as the application. Status is "OK" I can view freeview channels through HDHomerunSetup.
In SageTV, I add a new source, and can select the tuners. However, when I do a channel scan then sage scans up to 100 but does not find any channels. I am in the UK, so do not have a guide. Do I need to manually add each channel, and if so how? cheers. |
Does the "digital antenna" setting in the UK cause it to scan to 100? In the US, it only scans 2-69 (the OTA digital TV frequency range). Just curious... if UK operates in the same range, perhaps the fact it is scanning to 100 could be an indicator of where the problem is.
Sorry I can't help much beyond that... don't know much about UK TV (except my wife watching all the British sitcoms!) ![]()
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 10 x64, Java 8, Gigabit network Drives: Several TB of internal SATA and external USB drives, no NAS or RAID or such... Software: SageTV v9x64, stock STV with ADM. Tuners: 4 tuners via (2) HDHomeruns (100% OTA, DIY antennas in the attic). Clients: Several HD300s, HD200s, even an old HD100, all on wired LAN. Latest firmware for each. |
I'm guessing this is the DVB-T version? I haven't dealt with its setup for anything other than the one for the US & Canada. But... did the scan in SageTV take a long time or did it scan quickly? If it took a long time, then it didn't see the .scn file that the HDHR software creates. (I'll need to find out if DVB-T setup is different for the HDHR... or even supported yet.)
It scanned quickly - about 15 seconds. Yes, it is the new DVB-T only just released this week in the UK.
Beta 6.4.2 HDHomerun (Mac) Scan Problem | jbilich | SageTV Beta Test Software | 1 | 05-18-2008 12:32 PM |
Unable to Scan for Channels under 6.3.8 | Madz | SageTV Beta Test Software | 5 | 02-06-2008 02:00 AM |
No scan of DVB-C channels | cmf | Hardware Support | 3 | 02-01-2008 11:42 AM |
Specify which channels to scan | StuckInTheMud | SageTV Software | 3 | 01-19-2008 05:36 PM |
Scan Channels for french Tv => TNT | INDIANS | SageTV Software | 1 | 12-02-2006 11:10 AM |
