Old 06-04-2008, 02:28 AM
henk99 henk99 is offline
Hauppauge MVP image turns green!
Hi,
I purchased a plasma tv last week and yesterday I connected my Media MVP to the scart input on the back of the TV (Panasonic 42PH85Z).
Normally the screen is blue, but now there is a very distinct Green color. Everything I try is green.
Is any1 familiar with this? Before this it was doing just fine on my older crt TV.
Henk
XP Pro SP2, SageTV v5.02.90, Athlon XP 3000+ (FSB 333 MHz), 2GB DDR RAM PC3200, 36 GB Western Digital Raptor, 200 GB Western Digital harddrive, Asus Radeon 9600 XTR, Plextor PX-708 8x DVD-/+RW, Pioneer 120S 48x CD-RW, PVR 150 MCE (2). Hauppauge MVP.
Old 06-04-2008, 03:24 AM
Menehune's Avatar
Menehune Menehune is offline
Not being from Europe, I'm taking a shot in the dark, but does the SCART input on the plasma have a setting for the type of signal on the input?
I can't find your TV model on Google.
I have had some projectors with VGA connectors that can carry different signals. The VGA connector could accept either RGB or Y/YB/YR signals. When the VGA input was set to the wrong type of signal, the pix was a washed out pink.
Old 06-04-2008, 06:45 AM
Originally Posted by henk99 View Post
Hi,
Henk
Have you checked for any bent pins? Red is carried on pins 15 and 13 (which are pins 4 and 5 along the 11 pin row). Maybe one of the wires "snapped" inside so if you have another cable? Otherwise follow Menehune's advice and see if there is something that needs to be changed.
Old 06-04-2008, 09:54 AM
PeterC PeterC is offline
I had the same problem with my Panasonic Plasma, If I recall I snipped the wire connected to pin 16 on the scart plug.
Try searching for "sync on green" on the hauppauge sites for more information.
Old 06-04-2008, 10:29 PM
Lucas Lucas is offline
I had the same issue and I ended up slightly pulling the scart plug out untli I could get the proper color.
3 x HD300s
Sage 6.1.9 and 6.2 beta KEEP LOCKING UP kambo SageTV Linux 6 11-18-2007 08:11 PM
Issues with MVP client, Neilm's Customizable Menus, and java version zubblwump SageTV Customizations 8 09-07-2006 10:12 AM
MVP daily hiccup backsix SageTV Beta Test Software 18 05-22-2006 11:37 AM
hauppauge remote not working with MVP when using SAGE vsieferm SageTV Media Extender 5 02-15-2006 01:03 AM
