Old 07-30-2012, 08:05 AM
ybrew ybrew is offline
SageTV Service stopping constantly
I don't use sage too much anymore, but I still have the server running and still can record over the air.
Hadn't checked the box in a few weeks and went to use it on Friday and the SageTV Service would die after a minute or two.
Nothing in the logs. 100% repeatable. Stopped all other unnecessary services.
Rebooted. Etc. No luck anywhere and nothing in the logs to say why it stopped.
I was able to fix it by using system restore.
Just curious if anyone else has seen something like this. I'm wondering if it might've been a windows update. It's all good now though.
Old 07-30-2012, 08:14 AM
This is usually caused by having autoupdate enabled for Java. Sage doesn't get shutdown so the update doesn't install all the new files. Turn off autoupdate for java and update only when ALL of the SageTV services have been shutdown and processes terminated.
Old 07-30-2012, 09:28 AM
Yeah, I've run into Java update issues before. It was really bad when I relied on Sage for everything and it happened.
But check for updates automatically isn't checked now.
And Notify Me: Before downloading is selected.
So it's not a Java thing.
When I had the java issue before, sage wouldn't even start. Here, it was starting, but failing everytime within a minute or two.
FWIW, i'm running Java 6, Update 29. I probably ought to update. The last time it checked for updates was Oct 31, 2011. (I'm not sure what was selected before doing the system restore - but I didn't change any settings after running system restore)
Old 07-30-2012, 09:33 AM
I'm gonna update Java now. But - first I'm creating a restore point labeled "Sage Working - Java 6.29"
Old 07-30-2012, 09:40 AM
Why would you want to update Java ? If it is working?
Old 07-30-2012, 09:45 AM
I've got a few other things on this box. I'm not sure everything that relies on Java, but I've got plex running as well as Serviio and a couple of other things.
So I want to keep Java current.
But - I get what you're saying - and that's why I created a restore point before doing anything.
I've now got Java 5 Update 5 running. Sage Service is up and running and everything else appears to be as well. In a couple of days if everything stays good, I'll create another system restore point for this build of Java. And I'll likely go another 6 or more months before upgrading it again.
Old 07-30-2012, 10:45 AM
You meant Java 7 update 5 - correct?
Old 07-30-2012, 10:46 AM
OOPs - yeah. Java 7.
WHS Sage Service Keeps Stopping Sector7g SageTV Software 25 04-14-2012 04:31 PM
Starting/Stopping SageTV Service Via Command Line PeteCress SageTV Software 2 01-03-2011 12:30 PM
Need help please!! Sage service constantly crashes when HD-PVR is installed popechild SageTV Beta Test Software 7 08-09-2008 08:57 AM
SageTV 3.07 constantly recording etrigan63 SageTV Beta Test Software 24 10-21-2005 09:52 AM
Service stopping suspend to ram silkshadow SageTV Software 1 09-22-2005 02:28 PM
