Resuming DVD playback always starts back at the beginning on Sage client
I recently watched a DVD I have stored as a VIDEO_TS folder on the Sage 6.6.2 client (on the same PC as my server) and stopped the movie in the middle. Shortly thereafter, I went back to play the movie and tried to resume playback, but it started at the beginning. I searched around and noticed some folks had issues but never saw a resolution or reason.
Any thoughts on how to resolve or troubleshoot further? Amazingly this is the first time using the resume playback feature despite using Sage for years.
Server: Sage 7.1.9 beta; Dell Inspiron 530; Windows 7 Ultimate 32-bit (UAC turned off); 2TB Internal SATA (TV Recordings) Storage: Synology DiskStation DS411+, RAID 5, 5x 2TB SATA for (DVDs/Music/Other Videos) Tuners: Ceton InfiniTV w/ Verizon FIOS cablecard (using babgvant's SageDCT plugin) Clients: 1x STP-HD300; 1x Acer Aspire Revo 3610 (Atom/Ion) w/ SageTV client (Win 7, EVR, FSE on) |
I don't have this issue. I've resumed both from PC clients and HD200s. As noted some users have this issue. I think we need to figure out what they (you) have in common. If I were to venture a guess I would think it has something to do with permissions. I notice you're server is on Vista. I'm curious to see if UAC is enabled or disabled. If enabled it may have something to do with the virtual store. Try giving all permissions to the user you are logged in as to the SageTV directory under Program Files. Mu guess is it needs to save that position somewhere and it either can't or it is saving it to the wrong place.
Did some more testing. This is just weird. I can resume playback from some DVD movies but not others. They are all stored as VIDEO_TS folders. Any reason why it would work for some but not others?
No differences that I can think of. All are ripped by same version of AnyDVD, full rips, and all stored on the same machine as my server (not moved around).
Open a ticket with support. They may want debug logs.
Bug report submitted. Will reply to this thread once I have an update or response.
Yes, there is a reason this will work for some DVD rips and not for others. The DVD format allows authors of DVD's to set permissions on what operations are allowed. They can block or disable the ff/rw buttons or the chapter fwd/ chapter rev buttons or the menu button. Separate permissions can be set for each chapter or title on the DVD. So, for example, they can make it so that you can't skip the FBI warning or the previews of other movies at the beginning of the disc.
Not every DVD puts restrictions on what you can do (just like not every DVD uses copy protection), but many do. Some DVD ripping software allows you to remove these restrictions when you rip the DVD. My guess is that the DVD's you are having problems with are configured so that you can't skip FBI warning and that is why Sage appears to be forgetting where you left off. Check the options in your ripping software and see if there is a setting that lets you "remove prohibited user operations (P-UOPS)" and try re-ripping the DVD's that are giving you trouble.
Nonetheless, I heard the following from SageTV support... we'll see how this goes: Code:
"One of the developers said this has to do with the way bookmarks are done in SageTV. Some DVDs don't allow you to skip to a certain part of the movie directly; which is what SageTV tries to do. So for those DVDs; bookmarks don't work. There's another way bookmarks can be done which are operating system/DVD-player specific which get around this problem; and we're looking into supporting that technique in future versions."
D. |
Submit a bug report then and be clear which versions of Sage worked and which didn't for the exact same ripped DVD. Give them debug logs of both as well.
Was this ever noted as an actual "bug" or was it determined not to be because I'm having similar issues except that it's not on a client and instead on my main installation. I had been running one of the first versions of V6 for a long time but just upgraded to the latest version the other day. This always worked in the past but it seems to not work at all right now. Each time I do the "resume playback" option it still starts the DVD completely over... even starting with the previews.
All movies just copied from the DVD drive to a hard drive folder (using AnyDVD). |
Playback error when Sage starts up automatically | Sacedog | SageTV Software | 2 | 02-24-2008 02:52 PM |
DVD playback and resuming where stopped | Sambo555 | SageTV Beta Test Software | 3 | 12-11-2006 09:20 PM |
DVD playback in Sage Client? | Surtr | SageTV Software | 2 | 01-25-2005 05:48 PM |
Button to go back to beginning or end of show? | tangfj | SageTV Beta Test Software | 1 | 04-12-2004 10:13 AM |
Sage Client Studdering issue with DVD playback | jbuszkie | SageTV Software | 12 | 01-23-2004 01:52 PM |
