Old 02-06-2008, 08:23 AM
garbageman garbageman is offline
Question adding pvr150
I am currently using a pvr 150 with the hauppauge blaster to control a starchoice stb. Channels changes have been just about perfect. I would like to add a second 150 for live tv. Could I add it, set it for a constant input open live tv and use the stb remote for the changing of the channels. I know I can't use the blaster on the second 150. bigger issue,Will adding a second 150 mess up the blaster set-up of the original 150? I will be ordering a usb-uirt and this should allow channel changes on both stbs'. I am more worried about adding the second pvr150 and having it mess with the blaster function of the first.
Old 02-06-2008, 11:46 AM
I think there is no rule of thumb on which one will be used in an installation.
Old 02-06-2008, 12:21 PM
Fastrack Fastrack is offline
Send a message via ICQ to Fastrack
I believe the Hauppauge drivers pick up the first Hardware ID and use that for the blaster. So you might have to change the Tuner setup to the one that it picks up first and use that with the Starchoice box.
Ben
Intel Core2Duo E6600 2.4GHz - Win7 64bit
Antenna: Homemade Gray-Hoverman DBGH, Channel Master 7777 pre-amp, Mid-60s CM Rotor
Tuners: HDHomeRun v1, Hauppauge HVR1600
Video: BenQ W5000 1080p, ASUS ATI 6670
Storage (10TB): Seagate 2TB, Hitachi Coolspin 2TB x 4 Data Drives + 2TB x 2 Parity Drives using FlexRaid 2.0 (RAID6 T2+)
SageTV: 7.1.9 Final ?
Old 02-06-2008, 12:34 PM
Am I safe to assume once a tuner is set up it will continue to boot up in the same order. I won't have to reset the tuners every time the computer is restarted.Hopefully the tuners are picked up in the same order each time.
Old 02-06-2008, 02:47 PM
That I'm not 100% sure of. You'd have to test it, but I think that's the way it works.
Ben
Tool: Clickfinder to XMLTV V 0.8.5 (31.07.2009) owilsky SageTV Germany 141 01-18-2011 02:24 AM
Recommended NAS? KJake Hardware Support 531 02-28-2010 11:59 AM
Seek issues in PVR150 recorded files... shodge SageTV Software 2 08-06-2006 07:22 PM
Sage/MVP stopped working! SagerX SageTV Media Extender 10 02-27-2006 08:40 PM
Adding CC support for PVR-150/500MCE? broderp SageTV Customizations 7 01-21-2005 02:36 PM
