Old 12-21-2008, 07:13 AM
HellerMD98's Avatar
HellerMD98 HellerMD98 is offline
HD200 as Germany-US placeshift clieent
This inquiry is a follow up to my (failed) placeshifting experiment from 7/2007. http://forums.sagetv.com/forums/showthread.php?t=25451
I am hoping that the HD200 might be perfect for Germany-US placeshifting. We'd set up SageTV on a PC with DVB-T as the signal source in Germany. It would record in PAL Then the HD200 would be the client/placeshift. Two questions:
1) If I have NTSC in the US, does the HD200 convert PAL to NTSC? That is, the SageTV recordings were from a PAL source but we would have the HD200 connected to an NTSC TV. (We do have a multistandard VCR with converter that we could use if need be.)
2) If one connects a hard drive to rear USB port, can the HD200 pre-fetch videos from the SageTV server in Germany? (I don't think we have sufficient bandwidth to watch without pre-fetching the videos
Thank in advance for all recommendations and replies!
Old 12-21-2008, 10:01 AM
What failed with the previous experiment?
Old 12-22-2008, 02:50 AM
HellerMD98's Avatar
Sorry, that was on another post http://forums.sagetv.com/forums/show...hlight=germany but basically SageTV worked fine, but it didn't have the correct DVB-T frequencies and I couldn't locate them before departing Germany. This week I will work on getting SageTV going, and while I can always use a computer as the placeshiffter, I want to know if I can use the HD200 to pre-fetch the files from SageTV in Germany so that they are local to me in the US before we watch them. We're only doing SD here. Thanks again for all replies!
Old 12-22-2008, 06:41 AM
It might be possible to download files now (I might be confused on that) but AFAIK there's no way for Sage to pre-download recordings. It will however transcode them on the fly so they can be viewed in real time.
Old 12-22-2008, 07:00 AM
wado1971's Avatar
wado1971 wado1971 is offline
The client can browse the server file system and then download to your local machine (not sure about the placeshifter). You might want to check your in-laws internet service agreement as to how much uploading is allowable each month.
I've done this the other way around and it worked well (not with an extender but a computer using the PS software).
HD200 Trial has expired arkboynko SageTV Media Extender 2 12-20-2008 11:07 PM
HD200 used as standalone len12121 SageTV HD Theater - Media Player 1 12-16-2008 05:07 PM
Sigma SMP8635LF (HD200) vs EM8620L (HD100) & Capability Video/Audio voidpt SageTV Media Extender 4 12-10-2008 04:56 PM
HD200 initial impressions jmv SageTV Media Extender 12 12-10-2008 11:56 AM
