Old 01-13-2010, 04:43 PM
ohpleaseno ohpleaseno is offline
Wiz.bin corrupt
last night my WHS did an automatic update, but didn't shut down properly in the interim process of restarting. Wiz.bin is corrupt.
I have the wiz.bak file, but it too is corrupt. I haven't done a backup of my sage folder in months (yeah, yeah, I know).
Is there any hope, or am I screwed. If I'm screwed, is there any way to get my recordings to show up in the recorded tv section or am I screwed? Is there some automatic renamer that will take the Episode ID number and convert it into a "How I Met Your Mother S05E10.mpg" format?
Server: WHS with 11TB of storage
Clients:1) HD-200 to a Samsung 32" Slimfit CRT HDTV 2) HD-200 to a Pioneer 26" X1 LCD
Tuners: 1) HD-Homerun 2) Avermedia USB ATSC
Twitter: ohpleaseno
Old 01-14-2010, 02:45 PM
What is telling you that the files are corrupt? And, if one does get corrupt, the other should be OK.
If you've installed any SageTV updates, SageTV will also automatically create a backup the next time you run it, so there may be wiz.bin.version# files in your SageTV dir.
Old 01-14-2010, 08:14 PM
After all of the recordings were missing from My TV, I went to the Sage folder, and there was now a Wiz.bin.corrupt0 file there. Wiz.bak was dated after the corruption. I loaded it in and it didn't work either.
I have no backups with dates.
Twitter: ohpleaseno
Old 01-15-2010, 01:46 PM
Could you do a few things so SageTV can check it out...
1) List the file sizes of Wiz.bin.corrupt0 and wiz.bak.
2) If you've started a new wiz.bin, rename it/make a backup copy elsewhere. Enable debug logging, copy Wiz.bin.corrupt0 to wiz.bin, try to start SageTV, then attach the resulting log file to a post. After you are done with the test, you can restore the wiz.bin backup & restart SageTV.
Thanks.
Corrupt Wiz.bin bjbeeson SageTV Linux 23 10-13-2008 04:58 AM
Corrupt Wiz.bin everytime I reboot dvd_maniac SageTV Software 3 04-01-2008 07:52 AM
Corrupt Wiz.bin Question CharleyZ SageTV Software 1 08-15-2007 09:09 AM
Anyway to recover a wiz.bin.corrupt file? jbuszkie SageTV Software 17 03-04-2006 12:28 PM
Corrupt Wiz.bin Wakecrash SageTV Beta Test Software 0 08-24-2005 06:03 PM
